Old 10-21-2013, 06:23 PM
defhand defhand is offline
94 Ford Thunderbird 4.6...air system/electrical issue
Good evening,
I recently wired in a new CD player in my car. Prior to hard wiring the aftermarket speaker wires, I was misled to believe that a connector tucked to the left of my glovebox / behind the console was what I needed to cut and wire into. After no sound came from those wires, it was obvious one or both of us was a complete idiot, and I wired up the correct speaker wires. Now, the problems:
1. My air will not run, lights and controls are not working. The display for temp control and outside temp is blank.
2. When I disconnect all but a black connector on the far left of the back of the control, the blower runs freely at full blast.
3. I have since lost the connector I removed. Attached is a photo of the exposed wires. O e purple wire is hot, and when connected to one of the other purple, the temp control display lights up "-188e OUTSIDE TEMP".
I am hoping someone might be able to tell me the correct combinations of wires to make this thing work again, or that there is a connector i can buy to rewire it together.
Thanks in advance!
Here is a link to the image: https://db.tt/KkcLvKJV
Old 10-21-2013, 06:29 PM
vgames33 vgames33 is offline
Re: 94 Ford Thunderbird 4.6...air system/electrical issue
I doubt anyone can ID the proper connector from that information. Your best bet would be a pick-n-pull type of junkyard so you can go look for yourself and cut out what you need.
Old 10-21-2013, 06:30 PM
Ahh i figured. can you access the image?
Old 10-21-2013, 06:34 PM
I looked at it. I skimmed the automatic HVAC schematics in Mitchells and didn't see a connector with that many purple wires in it.
Old 10-21-2013, 06:35 PM
If those wires all came from separate sides of an inline connector, you should be able to connect like colors together to eliminate the connector.
Old 10-21-2013, 06:48 PM
I tried that solution already and didn't have any luck.
Old 10-21-2013, 06:53 PM
also, the connector had no previous use. It must have been an option my tbird didn't come with.
Old 10-21-2013, 09:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Are you saying the connector was just dangling, not connected to anything? Were each of the wires in their own terminal, or were some wires tied together in the connector?
As a general rule of thumb, if there is a connector that is not used, and you are wiring in speakers to locations that work, the connector you're looking for will not be one that goes nowhere.
-Rod
Old 10-21-2013, 09:57 PM
Yes...made a huge mistake there. A few lessons learned. Not entirely sure actually, i don't recall what they looked like going in. It actually looked like a stock connector for audio to be honest :/
Old 10-21-2013, 09:58 PM
Male.
Old 10-21-2013, 10:02 PM
shorod's Avatar
SHO No Mo
Do you recall if the connector happened to look like this one?
-Rod
Old 10-21-2013, 10:04 PM
I believe so!
Old 10-21-2013, 10:05 PM
There are 2 black ground wires though.
Old 10-22-2013, 06:46 AM
shorod's Avatar
SHO No Mo
On the image below, can you point me to the location of the connector you cut? I looked at connectors related to the 1993 and 1995 climate control as well and didn't find a similar connector for the 1993 and found the same for the 1995, no black wires.
Does your car have the electronic automatic climate control? If not, where is the outside temperature reading displayed?
-Rod
Old 10-22-2013, 05:34 PM
Below is the image with the location circled in red. It was between the glovebox and console, attached to the metal with a white plastic nub.
https://www.dropbox.com/s/vo082r6ywp...ps5bfd8f66.jpg
Here is the exact air control/display that I have, image found online:
https://www.dropbox.com/s/107659nn2g...Sz7aL5dggA.jpg
