Old 10-21-2013, 04:01 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
atv rear end flush/fill
I have a 2005 trx250 (recon). Rear end oil is kinda dirty so I was wondering how to go about flushing out and filling it. I've got the oil (80w90), and I assume there's a drain plug somewhere...would I just pour in the oil and let it run through until the clean oil comes out the drain hole? When that part is done, how do I know how much oil to put back in, I don't see a full line. I was told it doesn't hold much (less than 3 ounces or something). From the photo can anyone tell me which is the drain plug/screw?
This ain't your grandma's car!!
Old 10-21-2013, 07:36 PM
gw84's Avatar
Re: atv rear end flush/fill
well i did some searching on youtube and found the drain plug. I let it drain for a good while then poured in new oil and saw some more dirty oil run out. finally when the fresh oil started to pour out I put the plug back in and filled it up til it hit the overflow hole. hope I did it right!
