Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 06-11-2003, 05:33 PM
ECKOdotCOMPLEX ECKOdotCOMPLEX is offline
Send a message via AIM to ECKOdotCOMPLEX Send a message via Yahoo to ECKOdotCOMPLEX
New Tranny?
As most of you know i just bought an Rx-7 (1986) and now its giving me HELLA trouble. its hard to shift into first. i usually have to jerk it back between 1st and 2nd to actually get it into first. also it grinds whenever i try to put it in reverse. but when the car is off it goes into gear, no problem. but this morning i tried to put it into gear and start it but it sounded like the car wasnt getting enough "juice" to turn over. its like it was barely cranking. so please...what is it gonna be? i can get a new engine and tranny with only 121k miles on it for $300. thanx.
Old 06-16-2003, 08:21 PM
BlackLabel6542 BlackLabel6542 is offline
Send a message via AIM to BlackLabel6542 Send a message via Yahoo to BlackLabel6542
i dunno about you but i bought my 7 about 3 months ago and it has 151k miles on it and my trany grinds going into reverse sometimes and has just started to grind a little if i dont go into 5th very very slowly.
any feedback will help
Drive hard, Skate hard, Rock hard, life is to short to live like a b!tch
Old 06-16-2003, 09:12 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
well, first off CONGRATS on the buy!
how to fix that..... adjust your clutch. check your free play, u need 10mm and a 12mm box wrenches (one of each) to fix it, and make sure that you aren't leaking fluid in the engine. your other problem might be worn out shifter bushings, 10 bux at your local mazda dealership, or buy some from racingbeat. if those don't help get rid of the grinding (i know that which u speak of) just make sure it's in gear before you let out on the clutch! getting it into gear when it is stopped - let it roll a couple of inches, then try again.
so yeah... freeplay!
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 06-18-2003, 01:34 AM
Steel's Avatar
Steel Steel is offline
You can find used trannys for real cheap that still run good, and if you can save up $1000, your engine could get rebulit, good as new.
1998 Regal Gs battery light and tranny whine after new tranny Drgsxr750 Regal 14 08-02-2010 07:01 PM
Swapping old '92 tranny for new tranny michelleg 4Runner/GX470 6 12-14-2004 01:38 PM
New Tranny for SR20DE+T? v_knot Engine 10 02-11-2002 11:07 AM
