| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
Civic Upgrades
What can be bought for a civic, down to the smallest detail(without changing the engine)that will make the car run better and faster? I'm talking everything, even if we are talking minimal change in hp/speed.
I'll list them in the order they should be done-
Cold air intake Short throw shifter Header/High flow cat/good cat-back exhaust atleast 2.25'', preferably 2.5'' Upgrade ignition-Wires, coil, etc. Chipped ECU Better clutch and light weight flywheel Cam gears Underdrive pulleys and crank pulley Upgrade fuel system-injectors, fuel pump, etc Intake manifold-also bigger throttle body Cam swap Limited slip differential Nitrous Oxide This is of course if you want to stay all-motor. Forced induction is a completely different scenerio. Also I only listed mods for the engine, I don't do outside that so for suspension upgrades some else should chime in here. |
i'll take over for the handling then.
Lowering of somesort springs coilovers Shocks struts tie bars strut bars sway bars bushing kit wider wheels (light wieight) better tires lightweight lugs (for looks really) brakes |
