Old 06-10-2003, 02:10 PM
doug grand am doug grand am is offline
help..programming 2003 for keyless entry
HELP!!! DOES ANY ONE KNOW THE PROGRAMMING PROCESS FOR THE 2003 PONTIAC GRAND AM KEYLESS ENTRY THANKS,,, DOUG
Doug Grand Am
Old 06-12-2003, 04:24 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
You have to take it to the dealer, it needs to be programmed through the BCM with a scan tool.
Here is the procedure anyway.
Transmitter Programming
Important
All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence.If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
Install a scan tool.
Turn ON the ignition with the engine OFF.
Select Remote Function Actuation.
Select Special Functions.
Select Program Key Fobs.
Select the number of key fobs to be programmed.
Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds. The Power Locks should cycle to confirm programming of the first fob is complete.
If you are programming more than one transmitter, repeat the previous step to program up to four transmitters.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
need programming instructions for keyless entry 99 blazer heddlites Problem Diagnosis 5 08-08-2008 09:59 PM
99 jeep grand cherokee programming instructions for keyless entry. mikris Grand Cherokee | Grand Cherokee SRT8 1 05-26-2005 09:53 PM
program 2003 suburban keyless entry remote gotham01c C/K 1 09-05-2004 01:27 AM
I Need Help Programming 92 Lesabre Keyless Entry slamjamm LeSabre 0 03-24-2003 07:38 PM
