Old 06-10-2003, 10:14 AM
doug294 doug294 is offline
Send a message via AIM to doug294
short shifter
Ok I tried to install my short shifter. One of the nuts won't come off, it just sits at the end of the bolt and spins. What is wrong with it? Is it stripped. I am scared to yank it off because how would I replace the bolt if it messes it up.
Old 06-10-2003, 10:21 AM
lowboy lowboy is offline
Send a message via AIM to lowboy
dude there are 4 bolts theat secure the shifter to the body
2 of them keep the linkage on the body and the other 2 hold the shifter in its housing.
i had to cut the 2 that hold the shifter in its housing cause they were so rusted, however i would not cut the ones that hoold the entire linkage to the car,
the smaller 2 can be replaced however
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Which one dude?? Details & pics help!!!!
HA ! I have been wanting to use that smilie!!
Now - with that said..I assume you are talking about the square headed bolts that hold the shifter into the hole in the car. You need a second person to hold them with a set of vice grips or something...that is the stupidest design I have ever seen. Then replace them with some regular bolts when you reassemble.
Edit- oh some dude beat me to it...yeah..what he said
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 06-10-2003, 01:49 PM
its the first two on the bottom of the car. The one you see first
Old 06-11-2003, 12:37 AM
erbinone's Avatar
erbinone erbinone is offline
I think I know the answer to this but. What short shifter do I need for my 91 hatch w/ a GSR swap?? Will a 94-00 stock GSR shifter work?? Is the skunk2 short shifter worth it??
Old 06-11-2003, 01:09 AM
91civicDXdude's Avatar
they're all the same, as far as mounting. some people seem to have trouble with the generic ebay ones breaking, but i've never heard of anything like that personally.
Actually, i've found that Ractive ones are pretty good, they ahve a ball bearing bushing for the bottom, instead of an open metal hole. Hurst are good too. My buddies normally make their own with the stock shifter, if you're handy with a welder, you can make your own too. what you do is cut the shifter off *BELOW* the pivot point, weld a piece of steel in there to extend it down, and weld the bottom part back on. Its not the shortness of the stick, its the longness of the lower pivot part that makes it an actual short throw.
Old 06-11-2003, 03:09 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
with yoru talking about the 2 bolts that are screwed into the back rubber or your taking about the 2 nuts taht are screwed onto the stud infront and inback of the shifter. if your talking about those 2 nuts, what u might have to do is get like a vice grip or something to hold the top so you can unscrew the nuts, because hte top of those studs, like goes into a square hole, so it kind like holds it in place but they dont really stay in there so thats why u gotta hold it witha vice grip or something. other than that, if your talking about the 2 bolts in the back that go through the rubber, that should be hard to get out. that should be it for getting the shifter out
Team Lonely Drivers
Old 06-11-2003, 07:06 AM
Rufes1's Avatar
Rufes1 Rufes1 is offline
Send a message via ICQ to Rufes1
I have some jap brand one and someone said you should be able to stand on it withoput it breaking. So I did and it held up fine..
then again i only way 50 odd kilos
where can i find a short shifter with bronze shifter brushings to make for nice, tigh limer MX-3 1 03-31-2005 03:35 PM
Is there any downside to getting the UUC Short Shifter? Seriously! (more) Dean323i 3 Series 1 10-12-2001 03:27 PM
Yes just bought me a pacesetter short shifter...now I have to install it! zykotik General 7 09-06-2001 12:00 AM
Stillen Short Shifter jmgladden General 3 08-23-2001 12:50 PM
short shifters... jcl603 General 10 07-11-2001 12:49 AM
