Go Back   Automotive Forums Car Chat > Chevrolet > Prism
Old 10-14-2013, 04:56 PM
sbagdon sbagdon is offline
Oil TEMP Sensor Location?
Hooked up an iPhone obd-ii reader, and see that the code for oil TEMP is showing -40C. The pcm is putting out a value on the CAN bus, yet wondering what -40C means? Is it a phantom-code, or is there really a sensor that's gone bad? I believe I've found the oil PRESSURE sensor, yet can't find an oil TEMP sensor.
Is there really an oil TEMP sensor on this motor?
Thanks!
Old 10-14-2013, 05:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Oil TEMP Sensor Location?
What was the code? What year and engine do you have?
Old 10-14-2013, 07:48 PM
No CEL or MIL code.
Reading the CAN Bus with a ELM 327, to EngineLink. CAN Bus code is 015C. Value reported is -40C.
Engine Coolant, Throttle Position, Relative Throtttle Position, Boost/Vacuum, Engine RPM, Speed, etc, all return valid values.
98 1.8L Auto.
Old 10-14-2013, 08:08 PM
maxwedge maxwedge is offline
A990 racer
Could be wrong here but I do not think you have an oil temp sensor in that car, so you see a default reading.
Old 10-15-2013, 06:57 AM
Makes sense, yet interesting. I've seen both no-data, and valid-data, yet not default-data. Thanks!
Old 10-15-2013, 10:23 AM
gmtech1's Avatar
After doing some digging on Alldata, I agree with Max. Not seeing a oil temp sensor called out on that vehicle. So a default reading it is.
Old 10-15-2013, 10:27 AM
Sounds cool, just suprised, I've never seen a CAN Bus with invalid data. Either "0" or something valid, yet nothing like -40C.
Hey, learn something new, every day. ; )
