Old 10-14-2013, 09:38 AM
ryanusrey2012 ryanusrey2012 is offline
1990 Chevy K1500 Ground issue?
I have a 90 K1500 and as it has a lift kit on it including body lift so there is an auxillary electric fan instead of mechanical. One day i was driving my battery fell out of place and the plastic got melted off by a heater core hose. Ever since then everything electrical (except the starter) is only working half stat. It is not the battery or the terminal because i replaced them both. I found a broken chassis ground (firewall to frame) and replaced it and it did not fix the problem. My question is, did i replace the wrong ground or put it in the wrong spot or am i supposed to attach the ground from firewall to engine block? this is a 5.7 350 tbi with 227,XXX miles on it.
Old 10-14-2013, 10:28 AM
jdl jdl is offline
Re: 1990 Chevy K1500 Ground issue?
With vehicle running, the alternator should supply voltage to electricals. Is the charging system, working?
Old 10-14-2013, 02:26 PM
j cAT j cAT is offline
the engine need be grounded to the sheet metal body metal . the battery ground goes to the engine block and the body ground also
Old 10-14-2013, 08:03 PM
Schurkey Schurkey is offline
More accurately, the body needs to be grounded to the engine, which has the main ground cable to the negative post of the battery.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
The Following User Says Thank You to Schurkey For This Useful Post:
ryanusrey2012 (10-15-2013)
Old 10-15-2013, 08:58 AM
yes the charging system does work when running but as i drive down the road everything electrical in the vehicle will be working half stat and will sometimes very briefly flicker back on to full power than go back. This also affects all my gauges
Old 10-15-2013, 09:55 AM
So what you guys are saying is where the ground from the battery runs to the block i need to run another wire from there to the body, not the firewall?
Old 10-15-2013, 10:41 AM
jdl jdl is offline
I've seen faulty battery cable cause flickering. A lot of makes and models have negative battery cable going to alternator bracket.
I've seen the negative battery cable connected to the engine, where it was almost impossible to get at. When replacing the cable, I moved it to the alternator bracket. Everything worked fine and easy to get at.
intermittent issues can be a pain to track.
Old 10-15-2013, 11:01 AM
1. What, exactly, is "half stat"?
2. I would be looking at the lighter-gauge (perhaps 10 or 8 gauge) cable that is supposed to be part of the main positive battery cable, which supplies power to the distribution system under the plastic cover on the right side of the firewall.
Old 10-15-2013, 02:51 PM
hmmm before i replaced the terminals i knid of did suspect that positive wire and when i hooked it up i did not exactly ensure that it had good conection ill check that out. And when i said "half stat" i meant exactly that it is all working on low voltage.
Old 10-15-2013, 03:55 PM
aleekat aleekat is offline
Did you replace just the terminals or the entire cables?
Corrosion can be down under the insulation causing all types of current draw issues.
Post back, that's what makes Forums Work.
Old 10-15-2013, 03:57 PM
lets say you have good cables. clean connections no green colored wire etc /// which I doubt is the case here . then we get into loose fuse sockets and the fuse links that are hidden in the wire loom sometimes.
with your "the battery fell " tells me a lot about this trucks condition and care .
Old 10-16-2013, 07:45 AM
Well I ran a new ground from the top of the engine block to the body and it resolved my problem thank you guys for your input. It is still dropping 60mV across the body ground system but i believe that is acceptable right?
Tags
electrical , engine , ground , lights
