Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-13-2013, 11:59 PM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Tail light harness swap?
I have a '98 Ram 3500 with the factory tow package & 7 pin RV system. It's working fine, but after a couple rewiring jobs, it's getting kind of raggedy looking. Can anyone offer advice on what stock harness (1/2 ton, 3/4 ton. 1 ton, anything else? maybe Durango?) would swap over? I'd like a 'Plug & Play' fix on this as I have to replace the bed, and would like to get the harness fixed while the bed is off.
I can do the rewire if I have to, but need the color codes & pin out assignments if anyone has that?
Thanks
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 10-14-2013, 08:42 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Tail light harness swap?
I super agree with your plug-n-play wire replacement. You notice all the cars burned up on the side of the road between Christmas and New Year?
Yup, cut-n-tape wiring jobs on those Christmas present radios.
You might write down the colors on your wires then check the boneyards for a 1994-2002, 3500-2500-1500 w/trailer tow package.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
