Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-13-2013, 07:23 PM
sbcb62 sbcb62 is offline
2000 Ram 1500 Intermittent Transmission leak
I'm working on a 2000 Ram 1500, 5.2L (318 cid) Auto trans 4x4
Has a huge intermittent tranny leak. When it's warm (after running for several hours) will dump most of the fluid within a couple minutes. Looks like it's coming from the front pump.
The front pump seal was replaced and the torque converter doesn't appear to be gouged, cracked or scored near the seal.
I drilled out the anti drainback valve in the cooler line and backflushed the rad/cooler and it's still doing it.
Any ideas???
Old 10-13-2013, 08:19 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2000 Ram 1500 Intermittent Transmission leak
Did you replace the front pump bushing? The tolerances must be in spec or the seal will not hold.
Here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
The Following User Says Thank You to Chris Stewart For This Useful Post:
sbcb62 (10-14-2013)
Old 10-14-2013, 11:44 AM
Thanks for the manual, that's awesome.
Would that cause the intermittent leak though? I've run this thing on the hoist for literally 3 hours and it's dry as a bone. three days later the thing blows out 2 or 3 quarts, we fill it up and it's good to go again...
Old 10-14-2013, 09:36 PM
AF - Advisor
You know when one gets that vibration in the seat and floorboard that comes & goes every second? That's the worn front bushing or input shaft bearing/bushing. It would be a failing front wheel bearing if you felt it in the steering wheel too.
I'm gonna guess if it's not in a resonant vibration mode, maybe it won't leak but I'm certainly not a transmission Pro.
Old 10-16-2013, 05:18 PM
OK, I get it... Makes sense, thanks again.
Tags
1500 , dodge , leak , transmission
