Old 10-13-2013, 05:23 PM
awinther awinther is offline
Unhappy 2002 Voyager 3,3, AC/Heating problem
Got a 2002 Grand Voyager (as we name it in Europe), 3,3 AWD, with AC/Heating problems.
No matter the temperature setting, from 15C to 29, it will blow with same very hot air. AC working when setting the temp to LO.
Going from LO to 15 deg C, youŽll hear a "clunk", as if a door closes, and the warm air will start to flow through the vents.
Tried all the calibration possibilities known to me (ON+Recirc), and it will end with no faults, but to no good effect on the problem.
Does anyone know what the "ON+AC" mode does? Been in that mode - but do not know what it does, or if IŽm supposed to do anything.
Annoying - and haven't got a clue, other than the "thump" I hear when, possibly, the blend door closes, might be a problem, since I would expect the blend to be more gradually invoked.
Any suggestions?
Old 11-15-2013, 12:07 AM
Bill Grissom Bill Grissom is offline
Re: 2002 Voyager 3,3, AC/Heating problem
Do you have the Automatic Temperature Control, with digital indicators, like me? Mine also appears to act quirky. I replaced the AC compressor last summer and it doesn't blow cool enough, so my wife claims I am incompetent, or the Duracool refrigerant I used is the problem. What a way to talk to a guy with an MS in Mechanical Engineering. Anyway, I noticed that very cold air blows out of one of the middle vents, while much warmer air comes from the others. Also, the return line to the AC compressor is cold, so the AC evaporator must be cold. I conclude that the controller is allowing either hot air from the heater core or from outside (>38 C days are common here), even when we set both dual zones at max cold. I do have a spare ATC I got cheap on ebay a year ago (another problem I fixed without it), so I'll try that when I get time. No need to fuss over lack of AC for the next 6 months.
Old 11-15-2013, 02:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
You may need to head to a shop and have the codes read. Not the typical powertrain codes everyone reads with a typical scanner. Doesn't come up too often but I think they fall under "Body" codes and could be "Communication" codes They start with a B or U rather than the typical P.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
