Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 10-12-2013, 08:02 PM   #1
D.Boatman
88 s10 blazer 2.8 tbi. HELP!
Hello, I am new to this site, forums all together really so please have patience with me. Anyway I have a 88 s10 blazer that will not start, I've replaced fuel pump, filter, charcoal canister, also the rotor, cap, plug wires, module, pick up coil and ignition coil. Before I changed the pickup, it would start till it warmed up then die, wouldn't start again unless I gave it gas, if I held it steady the rpm would fluctuate but stay running till I let go of the throttle. Now that I've replaced the pickup coil it turns over, I do have spark but it will not start, thank you for your time and any ideas would be greatly appreciated
UPDATE: bought a code reader all I'm getting is code 12 wich is no distributor signal to ecm. Like I said I e replaced both the mudule and pick up coil. Any ideas what could be wrong?
Last edited by D.Boatman; 10-13-2013 at 04:45 PM. Reason: Stinkin' spell check on iOS
D.Boatman is offline   Reply With Quote
Old 10-13-2013, 08:47 PM   #2
82Stang
Re: 88 s10 blazer 2.8 tbi. HELP!
You could spray some carb cleaner down the throttle body then try starting. If it helps, then you have a fuel issue.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
82Stang is offline   Reply With Quote
Old 10-14-2013, 09:54 PM   #3
D.Boatman
I tried the starter fluid with the same result, I can see the fuel spraying from the I injectors so I really think it's not a fuel issue. I've got spark, (believe it or not considering im getting a code 12 stating i dont have distributor signal to the ecm) fuel and compression for sure, and on the timing I set it top dead center and set the distributor pointing at the number one plug, and still nothing, if my timing is off, it would at least try, right? And back fire ? Thank you for your time
