Old 10-12-2013, 12:56 AM
Emerson S Vica's Avatar
Emerson S Vica Emerson S Vica is offline
Yamaha TZ 350 K 1981 Prototype
Hello guys, let's start another project, this is a Yamaha TZ 350 K 1981 Prototype.
The difficulty in making this model was not having pictures, everything was based on a text with the technical details and a brief comment about the engine derived from the TZ 750.
Used for the design of the kit Tamiya 14026 Yamaha YZR 500 Kenny Roberts 1/12 scale.
The fuel tank,
Old 10-12-2013, 03:10 AM
Mr. Jekyll's Avatar
Mr. Jekyll Mr. Jekyll is offline
Re: Yamaha TZ 350 K 1981 Prototype
I like your WIP. Waiting to see more progress
Old 10-12-2013, 03:54 PM
Thanks for visiting Jekyll.
Old 10-12-2013, 04:57 PM
Making changes to the bike frame, beside the original to make the comparison.
Rear fork and shock-absorber,
The Front Fork, removed the chrome parts and also a caliper and brake discs on the right side, because the technical details, this bike possessed single disc brake at the front.
Primer was applied on all parts.
The top plate with semi-handlebar levers and reservoir oil hydraulic brake.
The plan was to redo the semi-handlebars, but decided to leave as it was, just changed the angle of the throttle.
Old 10-12-2013, 05:38 PM
In reference engine was derived from the TZ750 (inline four-cylinder two-stroke) cut the original engine to the two cylinders TZ350, separated the cylinders of the engine block.
The water pump is the same as the TZ750, is located inside the engine.
Following the references covers the engine with dry clutch and ignition system are the same.
I will use only two exhausts, here with the cracks filled injection and welds made​​.
The TZ350 radiator is smaller, cut a little unique.
I would like the opinion of you, and I thank the visits.
Old 10-12-2013, 05:52 PM
renatokrk renatokrk is offline
M. Emerson!
Son travail devient merveilleux. Je vais regarder ą coup sūr, et certainement sera parfait.
Cālin
Old 10-14-2013, 09:32 PM
John18d John18d is offline
you are embarking on an interesting project - and it looks like you are off to a great start
I will follow you thread with interest
John
Old 02-06-2014, 03:19 AM
joelwideqvist joelwideqvist is offline
Interesting build! Keep it coming!
Old 04-15-2014, 09:06 PM
Let the sequence of work, changes in the fairing,
I will use only two of the original cylinder engine,
Exhausts with welds made ​​and the holes filled injection side of the original exhaust kit
Instruments, tachometer and thermometer panel.
Modified chassis in support of cranksets and the ass steering damper housing and support
The front fork removal of the brake caliper on one side
Old 04-15-2014, 09:34 PM
Engine
Carburators
Assembly and Detailing
front wheel
Clutch lever with spring return
Radiator
Assembly
Exhaust with tips
YPVS
Assembly
The Following User Says Thank You to Emerson S Vica For This Useful Post:
Kuya (07-10-2021)
Old 04-15-2014, 11:45 PM
Wow Emerson - really nice work and attention to detail
this conversion is really coming nicely
do you have a TZ local that you can look at or is this all from books?
Very nice indeed
John
Old 04-17-2014, 08:01 PM
Hello John, thanks for visiting and the compliments, here in Brazil there is only one TZ350, restored by a collector, this bike belonged to the pilot Adu Celso, participated in competitions of the world in the 70s, however the owner does not allow to see her, researched references on the internet, I saw a text on the internet without photos on this bike, the 350cc category competed in the world until 1981, got some photos of the last TZ 350 in regional championships in the United States, Canada, Australia and Europe, joined the references to make this kit.
I like motorcycles classical competition mainly from Yamaha and Kawasaki motorcycles 2-stroke engines are incredible.
My project is to make the beginning by Yamaha 50cc, I have done the TZ125 '93 and TZ250 '94 was now ready to TZ350.
Soon I finish posting the rest of the job, thanks for the comments.
hug
Emerson
Old 04-17-2014, 10:44 PM
Emerson - really excellent attention to details for not have a TZ350 around to use as a reference
I've been thinking of maybe trying to do a TZ750 from the early 80's
John
Old 07-02-2014, 08:48 PM
Giving the sequence assembly
Well work finished, let the photos,
I appreciate the visits and we go to the next project,
Thank you
Old 07-04-2014, 10:15 AM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
Absolutely fantastic build, and enjoyable to see the end result.
Just one thing about the final paint work, the number boards should be blue, and not yellow.
The 350 class used blue backgrounds for the race numbers, whereas the 500's used yellow, other than that, spectacular.
gpz900ra7.
MY 1:1 toy
