Old 10-09-2013, 04:02 PM
olliek olliek is offline
RIP Windstar 2000
So, was driving my windstar home from kids hockey game about 50 miles away. Mostly on the interstate. Turn into my driveway and the engine starts making a rattling noise, the idle is rough and the whole car starts shaking.
Had the mechanic we use take a look it, all i needed to know whether it would be more than $100 as i would throw the towel above 100. Guess that's me and windstars. I was trying to get it over the winter and had just spent 600 on tire rods/two new tires plus a new battery.
Still wonder what it could have been as it was literally running fine until I turned into our driveway.
Windstar 2000 LX 3.8l
Old 10-09-2013, 06:51 PM
rickisrad rickisrad is offline
Re: RIP Windstar 2000
It could be as simple as a coil pack misfiring or something of that sort. Not much you can do for under a hundred bucks. If it happened out of nowhere and pulling into a driveway I would suspect that it is in the engine management system and not internal engine.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 10-10-2013, 08:00 AM
northern piper's Avatar
northern piper northern piper is offline
for sure find out what's up with it. Don't pull the plug because a vac line burst (for example) and it's running horribly. Spend the $100 and find out, or find someone who can help for beer.
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 10-10-2013, 10:03 AM
12Ounce 12Ounce is offline
If the fluids have been maintained, there is little likely wrong with the basic crankcase of this engine ... it is really strong. But there are a number of troubling small things that can cause problems ... if you can get an analysis by a good mechanic for $100, then do it. An analysis should include a compression test to cover all bases...may not be able to get that for $100 ... depends.
Our '99 is about to hit 380k miles ... and it needs attention ... but I intend to keep it going for about twice that.
