Old 10-06-2013, 07:11 PM
mountaindew11 mountaindew11 is offline
97 silverado tailgate latch
on my tailgate my latch handle can be pulled all the way up and it wont release the tailgate unless I pull up on it real hard.Do I need a new handle or something else
Old 10-07-2013, 03:04 PM
yakkk yakkk is offline
Re: 97 silverado tailgate latch
You might be able to salvage it - with the handle stuck open, spray some WD40 or other anti-sieze compound on the hinges inside and work the handle until it moves freely. Once it's working freely spray the hinges with lithium grease to prevent it from binding.
Old 10-15-2013, 04:42 PM
I did what you said and it seamed to help.Thanks
Old 10-16-2013, 02:28 AM
EgbertGeorgy's Avatar
EgbertGeorgy EgbertGeorgy is offline
WD 40 is the answer to most automotive problems and not restricted to just corroded hinges or lubrication. Just the other day I too had a similar problem with the window winder of my office vehicle. I simply opened up the door panels and gave the mechanism an overload of the spray can and it was good to go. You could also refer maintenance tips like I do to know more on DIY and repair procedures online.
Old 10-16-2013, 07:28 AM
ken_man_1 ken_man_1 is offline
@mountaindew11, there is a wonderful product called Fluid Film.
http://www.fluid-film.com/
This stuff will coat and protect the crucial points that cause the tailgate to stick. Not only that, but it won't dry up or cause caking.
Give it a shot! I have 20 truck fleet, I use it on everything...and not as often as I did WD-40.
