Old 09-27-2013, 03:44 PM
klinad klinad is offline
need help with plasti kote paints
the plasti kote fast dry enamel spray can is the only one i get easily get.And i applied several coats over a primed body. The problem is it says it will dry throughtly in 3 hours but the paint seemed never to get dry...i think it‘s mainly because the wet weather..
So my question is what can i do to accelerate drying progress or i should just wait for another couple of days? Thank you!
Old 09-27-2013, 04:27 PM
stevenoble's Avatar
Re: need help with plasti kote paints
No way Plasti Kote will dry in 3 hours from my experience. Takes a very long time to dry. Only way to accelerate the drying time is to put the painted parts in a warmer place. But not somewhere too warm as you don't want the plastic parts to melt. Ideal place is the airing cupboard if you have one..?? Or place in an open cardboard box near to a radiator but not directly on it. Bear in mind though that they can take a long time to properly dry.
Steve Noble
The Following User Says Thank You to stevenoble For This Useful Post:
klinad (09-27-2013)
Old 09-27-2013, 04:46 PM
Thank you very much! i have a cupboard i 'll try place it near a radiator. i thought that might get dry faster than acrylic and it seems i should change my mind..
BTW, How long do you think it can dry thoroughly?
Old 09-27-2013, 06:31 PM
MerlinPro MerlinPro is offline
Do not get the model hotter than 105F. You can keep at that temp for 4-6 hours.
Merlin
Old 09-27-2013, 06:51 PM
stevenoble's Avatar
I've had some enamels take a few weeks to dry properly. They often look dry but they can remain 'soft' for a long time after the initial drying period. I would say to give them longer than you think to be safe..
Steve Noble
Old 09-28-2013, 12:17 PM
Thank you !
Old 09-28-2013, 12:19 PM
That's a really loooong time. So i will let it dry longer not to left finger print on it. Thank you!
Old 09-28-2013, 04:33 PM
corvettekid_7684 corvettekid_7684 is offline
Humidity is a large factor. Do you have a dehumidifier?
Old 09-28-2013, 05:30 PM
Yeah,it's very humid here in Manchester...it does reduce the speed of drying....and sadly i dont have any dehumidifier....
Old 09-29-2013, 03:43 PM
ffreak's Avatar
ffreak ffreak is offline
Smile Re: need help with plasti kote paints
A food dehydrator should do the trick. Me and my friends use them constantly. We can spray a body and let it tack a few minutes and then place in the dehydrator and usually takes around 3 hours for laquer and acrylics. Enamel may take a bit longer. Preferably use one with a fan in it and adjust the temp around 100. We take the trays and cut the centers out of them all except one to place the body on. The others act as shims to raise the body up higher away from the heat source. I think you will be pleased with the results.
Old 09-30-2013, 07:03 PM
oh ,that's a great stuff.maybe i 'll try it.
Old 10-01-2013, 05:12 PM
CFarias's Avatar
CFarias CFarias is offline
I agree with ffreak. I live in south Texas where humidity can be a constant issue. I've used a food dehydrator for almost 15 years and it always works perfectly. I would highly recommend one. you will need one that has multiple trays, as mentioned already, a fan, and a temperature setting dial.
Old 10-05-2013, 05:45 PM
thank you very much !
