Old 06-09-2003, 06:50 PM
alphalanos alphalanos is offline
What is the most effective way to increase torque and low to mid end power?
96 EJ6. Future home of boosted B18C1.
Old 06-09-2003, 06:51 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
shorter gears and a cam with a lower lift tuned for low end power
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 06-09-2003, 08:42 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Supercharger
what vehicle???
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 06-09-2003, 08:45 PM
PWMAN's Avatar
It's not lift that matters it's duration. Less duration=more torque and power at lower RPM's, but less top end. Less duration + more lift=even better low end torque and power. More duration and less lift=screaming machine built for power.
Old 06-09-2003, 09:00 PM
Neutrino's Avatar
Yaya Master
you sure about that...doesn't vtec use i higher lift cam at high rpm and a low lift for low end?
(\__/)
Old 06-09-2003, 09:13 PM
PWMAN's Avatar
Positive, yes it is higher lift but the small lobes are rediculously small lift. So it's not really that much, the large lobes are like .412 intake, .379 exhaust lift. I forgot to include more duration high lift- best of both worlds but your engine has to be built to handle it, most stock engines cannot handle high lift high duration cams. Need to have beefier springs.
Old 06-09-2003, 10:58 PM
Steel's Avatar
Steel Steel is offline
a stroker kit too. Lengthens your stroke (duh) therefore slowing down your engine and losing power, but gaining a crapload of torque. That's useful for when you want to ultimatley make more torque than power.
Old 06-10-2003, 09:25 PM
454Casull 454Casull is offline
I'm pretty sure stroker kits increase power.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 06-11-2003, 03:23 PM
Steel's Avatar
well yeah, pretty much any aftermarket kit will. But iirc the purpose of stroker kits is to increase torque over power.
Old 06-11-2003, 10:14 PM
True, the length from center increases so torque increases, but I think it's just an easier way to increase displacement.
Old 06-18-2003, 10:18 PM
Warpspeed Warpspeed is offline
Stroking is not going to increase power.
The power you can develop is decided by airflow through the engine, there are lots of ways to increase airflow and power.
Whenever you bore, and/or stroke an engine, you are putting a bigger displacement engine under the same cylinder head(s) with the same induction and exhaust system. So torque will increase, but it will run out of breath sooner. It will develop the same power but at lower RPM, because the airflow through the engine is still going to be limited to the same amount.
So yes, boring or stroking will increase low and mid range torque.
So will positive displacement supercharging, or increasing the compression ratio, if that is feasible.
You could also try advancing the cam, but do not expect huge gains when doing this.
Cheers, Tony
whats the most power i can get from a d-series engine in a 1,700 budget pimpcrx_kid Let's get Technical! 2 12-31-2005 12:09 AM
Whats the side effect of getting a chip for your vehicle? XD_Edgar Tires and Wheels 3 06-27-2005 09:54 PM
Whats the most power? crazzysol Del Sol 5 10-13-2004 10:33 PM
how much and what is the most efficient way Pharty012 Integra 3 02-01-2002 10:15 PM
