Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-24-2013, 06:50 PM
dduran43 dduran43 is offline
help identify this part please?
On my 2000 bravada, this piece here broke, i noticed once it started making a clunk noise. I know it's connected to stabilizer, but I need to know what the part is where the metal is broken. https://db.tt/gXqWGT3F
Old 09-24-2013, 07:44 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: help identify this part please?
That's the front sway bar. The piece that's broken connects the sway bar to the lower A frame. Rotate the piece about 180 degrees and you'll see where is broke from the lower A frame.
I believe it can be repaired by a competent welder.
Remove the broken piece, tack it in place where it broke from then weld it up.
Be aware of fire dangers.
Old 09-26-2013, 07:20 AM
Thank you for the reply and info. I have a buddy who's actually a really good welder and was considering that as an option.
Old 09-26-2013, 08:49 PM
AF - Advisor
Very good. Let us know how it works out.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
