Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-19-2013, 08:57 AM
jallen8 jallen8 is offline
2004 Impala, intermittent extended crank time
Recently when I start my 2004 Impala, I sometimes now need to hold the key turned for extended crank for 'obviously longer than normal time' to start it, although it sometimes either immediately stalls or revs up after starting. I'm worried that this is a warning flag to eventual non-start problem.
Coincidentally, 6 years ago I had a similar problem, which was solved (after two trips to the dealership to find the problem) by replacing the fuel pressure regulator which had a leak. I recall in that case that it the problem was worse when the car sat for a while, which isn't necessarily the case now (although hard to remember what happened back then). So right now I'm thinking that's it's not the fuel pressure regulator again.
Any advice?
Jon
Old 09-19-2013, 06:37 PM
maxwedge maxwedge is offline
A990 racer
Re: 2004 Impala, intermittent extended crank time
Look inside the vacuum hose to the reg. see if there is any trace of gas, check fuel pressure at the port on the rail when cranking, look for about 47 psi.
Old 09-20-2013, 10:55 AM
I wasn't planning on doing any of the mechanic work myself (donno how).
Do you think it's the fuel pressure regulator leaking?
I've also noticed that it starts ok in the morning, and the problem seems to happen more often the hotter it is out. Also if I turn off the car right after driving it, and try to restart it, it restarts ok.
Old 09-20-2013, 06:49 PM
A990 racer
The 2cnd post info are the preliminary steps to diagnose this.
Old 09-21-2013, 04:09 PM
jyount jyount is offline
Something is leaking fuel pressure. You need a gauge. The most common place is the regulator. An injector, or the pump itself could be the cause too. Needs diagnosing. Throwing parts is expensive and 9 times out 10 it won't be the first one thrown at it, so money gets wasted in the process.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 10-01-2013, 04:12 PM
It was the fuel pressure regulator. Second time replaced it now (2004 Impala, replaced it in 2007 and now 2013), noticed that it went up like $50 in cost since 2007 too.
Old 10-02-2013, 11:12 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
jallen8,
I am glad to see you were able to have your concern resolved. If you have any concerns or questions, please do not hesitate to reach out to us via private message.
Erica Tiffany
GM Customer Care
Tags
2004 , crank , extended , impala , start
