Old 09-17-2013, 10:21 PM
21sprint 21sprint is offline
Got a 1998 Cavalier that intermittently blows 10A PCM in dash fuse?
I should have waited but changed the fuel pump and pump relay, someone else tried the ign module. It blows at weird times and I've tried shaking the wires and PCM with car running. Of course when the girl drives it she gets stranded with same fuse. I go get it and it never does..
Old 09-18-2013, 10:11 AM
Tech II Tech II is offline
Re: Got a 1998 Cavalier that intermittently blows 10A PCM in dash fuse?
A fuse usually feeds more than one "leg"....you need a schematic to see what it feeds......may even have to isolate each leg one at a time....
Old 10-10-2013, 10:17 PM
terrypg terrypg is offline
you did not say what engine but check gray wire on engine harness feeding injectors for rub through or pinch also try area left drivers floor pull up rug same color wire.
Old 10-12-2013, 01:00 AM
Thanks, but after finding out this guy drives this car on a driveway that a 4x4 would have trouble getting up, no kidding. I found the harness at the PCM was frazzled under the right front fender. One wire was bare and I tied the wires up and recovered them and now a happy customer...
