Old 09-12-2013, 03:51 PM
Antorozco1 Antorozco1 is offline
Need help in finding a scan tool
hey guys, iv heard coworkers mentioning that their is certain people that have a certain type of laptop to be able to pinpoint and exact electrical problem and they would print out the problem and give it to the mechanic...any clues where this can be tool can be found????
Old 09-13-2013, 06:46 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Need help in finding a scan tool
You won't find any sort of laptop or scan tool that can pinpoint an "exact electrical problem", but there are several software packages, many for free, that along with an OBDII dongle (for 1996 and newer vehicles), can access powertrain diagnostic codes. These diagnostic codes are far from pinpointing an exact electrical issue. Instead they will identify a circuit that the PCM has used to identify an issue. The codes certainly won't tell a shop exactly what the problem is though.
-Rod
Old 09-13-2013, 10:48 PM
xuanphong.auto xuanphong.auto is offline
To diagnostic a automotive. We can user 1 in 2 method
1.Used diagnostic scan.This is Convenience equipment to scan fault of engine
It can used for many automotive.
Example: Lauch.....
2.Used software on laptop.
All automotive company almost provided software to diagnostic car is produced by them
but attached have to buy Specialized cab of them.
of course you only can diagnostic each their automotive
Old 09-16-2013, 10:53 PM
vgames33 vgames33 is offline
They are likely referring to a code reader. Your mechanic has one and will use it as step one in the diagnostic process. The trouble code is a starting point. The code identifies a circuit or sensor that isn't performing correctly. Its up to the mechanic to figure out why. No tool can say "fix this."
