Old 06-09-2003, 03:47 PM
funkdaflex1 funkdaflex1 is offline
b18a and b18b whats the difference really need to know!!
Hey whats up i got a b18 head im not sure if its a or b but i need a block but i dunno if getting a A block or a B block matters im swapping to the b18a/b motor into my civic becuase my greddy turbo kit will bolt right up to it. Ive found a b18a block for really cheap off a auto trany teg its a long block to if it helps i honestly dont know the difference n e help and info is greatly apreciated
SOLD
V
D16y8-
-Greddy Turbocharger
-Greddy front mount intercooler
-Greddy type S BOV
-Greddy profec E-01 boost control
-Apexi N1 cat back exhaust
-Tokico Hp shocks
-Eiboch Sportline springs
-AEM cam gear
-MSD spark plug wires
-Walbro 255 fuel pump
-DC sports front upper strut bar
-B&M fuel pressure regulator
-B&M fuel psi gauge
-Tenzo R Pasion 5 17" white
-Hankooks ventus hr2 tires
-eclipse and mtx speakers
-Alpine CDA-7893
-Alpine XM radio module
Old 06-09-2003, 05:26 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Up till 92 the B18A was OBD 0, after that the difference is the tranny. The blocks are the same.
Old 06-10-2003, 04:17 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
nah, he needs to know if his head matters if its A or B, sorry i cant help you out, what year did you pull the motor from?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-10-2003, 04:19 PM
Head, block, doesn't matter, they are the same. The changes were the OBD in 92 and the tranny in 94, other than that they are the same. The latter as a whole produce 2 hp more, due more than likely to a better ECU, since they displaced the same and they ran the same compression.
Old 06-10-2003, 04:24 PM
i have no idea what year its from i got the head from a local shop for 100 bucks its the full head with distributor and it was just to good to pass up
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 06-10-2003, 04:32 PM
Whatever you're planning on doing wih the head, you need to make sure that the OBD electronics match the car it is going into.injectors, distributor, etc...
Old 06-10-2003, 04:34 PM
kool kool yeah the head came with the distributor and i think i might even have a honda tech put the motor in. what with work best or what do i have to use obd 1 or obd0?
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 06-10-2003, 04:48 PM
I'm assuming you're working with a 98 civic, as in your profile thing. You need to use OBD II parts, from a 96-98.
Old 06-10-2003, 07:34 PM
ok so i would use my obd2 ecu with the b18 motor right and what else or shoud i already have n e thing or n e thing i need to keep from the other motor.. and also what do i need with the block the guy said it comes with Oil Breather tank and the thermostat housing are the only extra items on the block itself. .......... Is that going to be a problem or are all the other parts easily found on ebay or other places he said it doesnt come with a oild pan either.
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 06-12-2003, 08:52 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
just a question but how come you are gonna buy a long block if you already have a head.
I dont nkow for sure but you can probably use your harness, maybe have to customize a few things, your ECU, maybe your injectors if the head you got is old enough to where they run off diufferent impedences or some electrical word like that. not sure when it changed tho. and depending on the MAP sensor type, you might have to use your TB if it fits, I had to do that but mine was both D series engines, but the manifolds were completely different but it still worked.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 06-13-2003, 12:50 PM
Well I found a guy selling a longblock for incredibly cheap i mean like pocket change cheap and i told him to just keep the head and sell that to and i'd give him the same price.
SOLD
V
D16y8-
-Greddy type S BOV
-Tokico Hp shocks
-AEM cam gear
-B&M fuel psi gauge
-Alpine CDA-7893
Old 06-21-2003, 01:35 AM
motoxracr16 motoxracr16 is offline
were to buy b18b motor and tranny
Im saving to buy a b18b ls motor does anyone know were i can get one for a good deal and not have the tranny be all messed up?
Dustin Alderman
Old 06-21-2003, 06:34 AM
Re: were to buy b18b motor and tranny
www.hmotorsonline.com
www.passwordjdm.com
www.importautosalvage.com
Old 06-23-2003, 10:09 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
I wanted to confirm on this thread for my own reference, the B18 in the 91 tegs is OBD0... correct? what generation of teg does the 91 fit in to? and is the OBD0 B18 a b18B or a b18A?
Old 06-24-2003, 04:53 AM
92> = OBD 0
92-95 = OBD I
96-98 = OBD II
99+ =OBD IIb
