Old 09-09-2013, 12:01 PM
cmdl cmdl is offline
Windshield-Roof Leak 1991 Honda Accord LX
Hi,
I have a question on a leak I have had from my roof. Its from a single point directly above the steering where the windshield meets the roof. I have looked at the black liner outside and it seems to be fine but I'm not sure if it has gaps between it and the windshield. I've used an entire tube of silicone from Autozone with not much success. I've used heavy duty packing tape on the outside with a lot of success. Unfortunately the tape doesn't last long in direct sunlight. Any ideas? Thanks.
Old 09-09-2013, 01:06 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Windshield-Roof Leak 1991 Honda Accord LX
I think the windshield will have to be removed and resealed. While it is out, inspect for rust anywhere around the windshield frame and repair if necessary.
Silicone repairs to the windshield area are hit or miss IMHO and tape just looks like crap and does not hold up as you have found.
Good luck..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
The Following User Says Thank You to Blt2Lst For This Useful Post:
cmdl (09-10-2013)
Old 09-10-2013, 01:47 PM
Thanks. I'll just go the tape route then given that it does perform. The car's paint is peeled at varying rates of decay and so it can't look any more like crap LOL. Plus, I can't remove the windshield myself and don't plan to invest in having someone else do the job. Appreciate your advice.
Old 09-10-2013, 06:12 PM
Blt2Lst's Avatar
In that case, I would try some Gorilla Tape, regular duct tape and packing tape do not hold up well on a cars exterior. I found this out the hard way..
1992 Camry LE 2.2
1996 Suzuki RMX250
cmdl (09-11-2013)
Old 09-11-2013, 10:55 AM
Will go for Gorilla Tape then. Thanks again.
