Old 09-08-2013, 10:47 AM
mstngcobrasvt98's Avatar
mstngcobrasvt98 mstngcobrasvt98 is offline
Send a message via AIM to mstngcobrasvt98 Send a message via Yahoo to mstngcobrasvt98
AMT Ford Probe
Found at a local car show swap meet. Not sure on color yet but I know turbo was in order as was some wiring.
And piping pretty much done
Was thinking of some decals, but with all the complex lines on the body there is no way of doing anything. Maybe just a paint job. Comments always welcome.
Just a good model of mine:
2 Fast 2 Furious Skyline
STOLEN!!!
Another go at it:
2 Fast 2 Furious Skyline.. Pt. 2
Old 09-09-2013, 12:32 PM
HondaSan72's Avatar
HondaSan72 HondaSan72 is offline
Re: AMT Ford Probe
Fantastic start... Love the turbo setup. What did you use to make the piping? Bends look really smooth. Can't wait to see more!!
Old 09-09-2013, 01:02 PM
Re: AMT Ford Probe
all of the tubing is small diameter solder. The main part of the turbo and downpipe are plastic rod with solder wrapped tightly around to make the snail sections. All bends are just hand bent. the only bend I used a tool with is the 90° after the turbo. decided to go with a color change paint as the body has a lot of edges. hopefully it will work out. thanks for the reply.
STOLEN!!!
Another go at it:
The Following User Says Thank You to mstngcobrasvt98 For This Useful Post:
HondaSan72 (09-10-2013)
Old 09-10-2013, 10:07 PM
Re: AMT Ford Probe
Quick update:
More solder work...just for you HondaSan. Exhaust is a little bit more tricky at times cause most cars run under the rear suspension. Can be a bit tight at times causing stance issues
Engine Bay, pretty plain
Will it all fit????
Thats all for now... Thanks for the comments.
STOLEN!!!
Another go at it:
Old 09-11-2013, 09:52 AM
HondaSan72's Avatar
Re: AMT Ford Probe
Exhaust pipe looks amazing... Flows so smoothly. Fantastic job!
Old 09-13-2013, 07:41 PM
Re: AMT Ford Probe
Finally got around to the window. I feel spoiled now with window masks...had to do this all freehand
And then to cut the roof supports without breaking the a pillars...just a bit of unwanted stuff to paint
Also, I did the taillights with foil. Also experimented with some aluminum tubing
and
Tried to make it look like bulbs and housings.
Hopefully getting the body, glass, interior and chassis together this weekend.
STOLEN!!!
Another go at it:
Old 09-21-2013, 03:31 AM
Orion37170's Avatar
Orion37170 Orion37170 is offline
Send a message via ICQ to Orion37170 Send a message via AIM to Orion37170 Send a message via MSN to Orion37170
Re: AMT Ford Probe
the rear lights look interesting, the circle at the corner is a bit strange.
Old 09-22-2013, 09:52 AM
Re: AMT Ford Probe
Yea, now that i look at it, it is weird. Guess I got carried away. Finally finished it. didn't realize how warped things were, only 3 wheels touch...
Thanks for watching. Going to start my 1:12 Tyrrell P34 I think. Stay Tuned.
STOLEN!!!
Another go at it:
