Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-07-2013, 11:10 PM
redbaron1 redbaron1 is offline
voltage ? 95 Dakota
1995 Dakota the orange & green wire to the injectors & coil has battery volt the wire to pcm 5 volt what Is the voltage used for? I thought the pcm used it to check circuits because the pcm grounds them to make them work. other wise why would you need voltage? just curious if any one new the answer?
