Old 06-09-2003, 03:33 PM
don1971 don1971 is offline
Explain the Cossie Driveline to me
Can someone who really knows what they are talking about explain the layout of the drivetrain in an AWD Cosworth Escort? I know it uses an MT 75 transmission and an independent rear suspension. How about the front? Do the axles come staight out of the tranny, or is there a short drive shaft to another separate differential/axle assembly up front.
Old 06-11-2003, 06:06 PM
tsunami racer tsunami racer is offline
to the best of my knowledge (which admittedly is not much) the escort RS cosworth is set up much like a truck with permanent 4wd as opposed to an scoobaru-type all-wheel drive system that throws power around.
the engine is mounted north/south unlike say a Mitsubishi Lancer Evolution that is still in the east/west configuration.
power is transfered to a center diff with planetary and viscous coupling and that goes back to the rear diff with the same.
from the center, it also goes to a front diff with planetary gear. the center diff is locked to split the torque 34% to the front, 66% to the rear.
