Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-05-2013, 07:32 PM
ethanaw ethanaw is offline
'08 impala, strange thing happening with heating
(posting for a friend)
Air only blows out hot when the car is moving.
Old 09-06-2013, 07:28 AM
Tech II Tech II is offline
Re: '08 impala, strange thing happening with heating
So idle, no heat? If you bring the rpm's up to say 2500, do you get heat?
If yes, then you could have a restriction in the heater core(partially plugged), but more likely, you have an air pocket that is restricting flow, caused by a coolant leak......Check the vehicle's coolant level when cold....
The Following User Says Thank You to Tech II For This Useful Post:
ethanaw (09-06-2013)
Old 09-06-2013, 07:59 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
ethanaw,
I am sorry your friend is having this concern. If your friend decides they would like to have their GM dealership look further into this concern, they can always reach out to us via private message. Please be sure to include name, VIN, address, and phone number.
Erica Tiffany
GM Customer Care
Old 09-06-2013, 11:26 AM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: '08 impala, strange thing happening with heating
Was the thermostat checked? Is the engine temp higher than normal?
Check for line restrictions?
Happiness is driving a Chevrolet!
The Following User Says Thank You to SierraK1500 For This Useful Post:
Tags
2008 , heater , heating , impala , issue
