Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 09-05-2013, 04:53 PM
Air4ceOne Air4ceOne is offline
Where is the water pump on a '95 Tercel?
Today when I was out, I noticed the temp, gauge climbing quickly every time I stopped at a red light. After getting home, I noticed antifreeze leaking. I seemed to be coming from the rear of the engine somewhere, but I couldn't see exactly where it was leaking from. I know the water pump will start leaking when it's going bad. Where exactly is it located on a 95 Tercel? I see some say it's behind the timing belt and others say it's on the rear of the engine.
Thanks for any help!
Old 09-06-2013, 11:20 AM
jdl jdl is offline
Re: Where is the water pump on a '95 Tercel?
Your lower radiator hose should go to the water pump. Sorry, I haven't found a picture?
Old 09-09-2013, 09:13 AM
Thanks, jdl. Luckily it wasn't the water pump. I took everything apart yesterday and found a split in the water inlet hose, underneath the intake manifold. It took me pretty much the entire day to get everything apart, replaced and back together. What a stupid place to put a hose. It's definitely not easy to get to.
Old 09-09-2013, 10:21 AM
jdl jdl is offline
Glad you found it, good job.
