Go Back   Automotive Forums Car Chat > Mitsubishi > Colt
Old 09-04-2013, 10:06 PM
byates22 byates22 is offline
Recharging the AC. 93 colt
I'm trying to figure out where the low pressure valve is so i can recharge the Freon. I found one valve but i think it is the high pressure valve. I have looked up and down the lines, by the compressor and where the lines enter into the firewall. The one valve i have found has no letters on the cap to designate if it is high or low.
The valve is on the lower diameter tube, the tubes that come off the compressor. I cannot find a valve on the bigger diameter tube at all.
Any idea of where it might be??
I have a 93 colt. It has a 1.8 liter in it that i swapped in from a 95 mirage.
Any help would be great!!!!
Old 09-04-2013, 10:08 PM
Re: Recharging the AC. 93 colt
Old 09-05-2013, 01:57 AM
DeltaP DeltaP is offline
That appears to be a high side port. Love the wiring! Is that wire nut acting as a switch?
Old 09-05-2013, 02:01 AM
I figured it was the high side..... any idea where the low would be.... and no that goes to aftermarket horns lol..... my car is pretty rigged right now....
Old 09-05-2013, 02:11 AM
Went as far as I could with the picture,can't see anything else. Can't remember that far back on Colt/Mirages. What state is the system in now?
Old 09-05-2013, 02:15 AM
Theres pressure. I push the valve stem and it releases only air. The compressor seems to come on when I turn the Ac on in the car. It will blow air slightly better then when the ac is off... it still is hot tho. I traced the lines everywhere I could and cant find another valve that looks like that
Old 09-05-2013, 09:09 PM
No one has any ideas??
Old 09-07-2013, 10:45 AM
Check the compressor itself. Something I remember tells me it's mounted on the compressor manifold.
