Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 09-04-2013, 01:33 AM
suncowiam suncowiam is offline
Coolant leak but no visible sign of leak
I've had to replace my radiator twice due to it overheating. I am noticing coolant level going down but I'm not seeing any signs of an external leak. My garage is saying it is probably internal and going into the engine. Says I probably have to replace the head gasket but that will be very expensive.
Could I get some further feedback on what it could be and what else I could do? I am also getting a check engine light on a "lean mixture" issue. Not sure if they are related.
Thanks
Old 09-04-2013, 05:35 PM
The Ruth's Avatar
The Ruth The Ruth is offline
Re: Coolant leak but no visible sign of leak
The lean mixture code shouldn't be related.. that is more than likely a MAF cleaning or replacement issue.
As far as the coolant issue.. this could be a bunch of things, unfortunately. Outside of a head gasket, it could be a tiny methodical leak in one of many places. Check your water pump, radiator hoses, overflow tank, and even the thermostat housing for any white residue.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
www.HelpUFindStuff.com
Old 09-04-2013, 05:56 PM
Hi,
Thanks for the suggestions. What is MAF concerning the lean mixture?
Old 09-05-2013, 07:53 AM
The Ruth's Avatar
Originally Posted by suncowiam View Post
Hi,
MAF = Mass Air Flow Sensor. It's a little plug that should be located right before the box with your air filter. You can get a can of MAF cleaner at any auto parts stores and simply unplug it, clean it and wait for it to dry, then plug it back in. A cheap start to solving that error code, and it should be done from time to time anyway.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
Old 09-06-2013, 12:28 PM
Thanks for the info. Much appreciated!
Old 09-06-2013, 05:59 PM
danielsatur danielsatur is offline
If all rubber hoses & plastic coolant recovery tank is good, try http://www.steelseal.com
Caution - Make sure your electric coolant fans are working proper with the HVAC on high cool max.
Any boil over will cause a coolant shortage.
Old 09-06-2013, 07:21 PM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
Does the car smell like burning coolant when you start it? and drive? Do you sparkplugs have excessive amounts of residue on them? Some mroe than others? There is a possible "temp to permanent" fix .. my honest mechanic . com KW block sealer costs 8 dollars, worth a try; run for 500 + miles, you will not have boil over or freeze protection, follow directions except run for 00+ miles
"He who makes a beast out of himself gets rid of the pain of being a man."---Dr Samuel Johnson
