Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-01-2013, 10:33 AM   #1
timothylloyd34
90 mustang 5.0 problem
Hello, 90 mustang gt, penny fell in cigeratte lighter now no dash lights ,radio, ele. turn mirror switch , and NO Headlights fuses are fin? if I jump light switch fuses with power everything works but goes out when highbeam turned on but will go on when held in flash mod, blinkers work but again no power to the fuse in fusebox ? nothing looks burnt ,try to trace but not my best with elec. ,also no horn ,please HELP>>>>>>>>>>>
timothylloyd34 is offline   Reply With Quote
Old 09-01-2013, 01:04 PM   #2
The Ruth
The Ruth's Avatar
Re: 90 mustang 5.0 problem
This is actually a pretty common nightmare in the fox bodies. It is usually caused by a short in the headlight switch. It will normally begin with the headlights and dash lights and can easily spread from there. Also make sure that you don't have anything shorted out behind the radio or instrument cluster. It's not fun, or easy to pull the cluster out, but if your switch is not the problem, then it is probably back there.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
www.HelpUFindStuff.com
The Ruth is offline   Reply With Quote
Old 09-02-2013, 07:56 AM   #3
timothylloyd34
no power to switch ? someone said maybe fuseable link in the line ?
Old 09-02-2013, 08:06 AM   #4
timothylloyd34
Still a problem with this could not find any wires burnt or anything blown fuses .
Old 09-30-2013, 07:55 PM   #5
The Ruth
The Ruth's Avatar
Unfortunately it is next to impossible to diagnose random electrical problems without physically getting into it and playing guess and test. Trust me, I've gone through this a few times with fox bodies. The best way is to get a voltage tester and just literally start going through everything one by one.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
