Old 08-28-2013, 12:11 PM
wjamaica4 wjamaica4 is offline
98 windstar stalls while driving
98 windstar stalls while driving, new crate engin, crate tranni less than a year old:
Stalls on excelleration, Stalls at low rpm, Stalls on turns, Stalls on decelleraton, Replaced the IAC-dealer part, New injectors. At this stage is it permissable to clean out the insice of the throttle with carb cleaner to remove deposits from throttle plate. New lower intake manafold. There appears to be no vacuum leaks.
Stalls occure at random
Old 08-28-2013, 04:10 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Re: 98 windstar stalls while driving
How old is the battery? Is it in good condition? I would have it tested for free at AutoZone or Advance Auto to rule out a weak or dying battery!
If battery check out OK start by checking a connections to Engine and PCM
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 08-28-2013, 04:22 PM
Thanks for you reply ED_Strong
I brought a platnum battery from auto zone awhile back. I will go back to check it out. Your right they can go bad anytime. I just put a new alternator in also. Will let you know.
Old 08-29-2013, 01:55 PM
Hey Ed_Strong
Battery excellent, will check conections
Old 09-03-2013, 08:26 AM
Checked connections at battery and grounds, electrition friend said I was loseing 1/2
volt from alternater to the battery.
My michanic disconnected the egr and I ran the car. All symtoms disapeared, however, in 2 days the engine check light came on for egr. That was no problem. It gave me the idea that the problem was where I never attempted to service because the manual told me not to. So, I said its a 98, the hell with it! The throtle plate was cakeing up with oil deposits. I hit that with carb cleaner to remove as much as possible then reinstalled the breather. Runs a whole lot better. I can bearly touch the accelorator and the entine will respond in kind. I use to rebuild carbs in the military, so one to the first things I did after buying a used car was to rebuild the carb. With fuel injection, now, I'm looking for oil deposits in the throtle body. I will remove the throtle body and give it a good cleaning. Then go back to my cold air breather.
