Go Back   Automotive Forums Car Chat > Mercury > Milan
Old 08-27-2013, 09:07 AM
94&92Astro 94&92Astro is offline
Milan died--fuel pressure good--spark?
08 Milan with v6 auto trans
Was running great when it suddenly spit sputtered and died--I checked fuel pressure and looked good so I put a bit of starting fluid down its throat to see if I could get a pulse but nothing---cranks and wont hit a lick.. fixing to go check spark--no codes showing--just fishing for ideas now?
Old 08-27-2013, 12:16 PM
Re: Milan died--fuel pressure good--spark?
As suspected I have good fuel pressure but NO SPARK at the plug!
Has 60k miles and clean as a whistle---No fault codes--Do I suspect computer as has 6 individual coils---fuse----Ideas? Time to call a real mechanic
Old 08-28-2013, 12:17 PM
OK ---I will just continue this thread solo as time permits in case it will help someone in the future.
My phone calls and research tell me this could very well be a pcm - ecm issue--all coils are not sparking with no codes. I found a few PCMs on nearly identical cars I wouldn't mind taking a chance on but PCM nodel numbers vary slightly so I just don't know squat about them... Still going to check the crank position sensor and go over the fuses again---Frustrating---Car was running great now it is a yard ornament--wife not happy in my old chevy truck---and when she aint happy....well any help appreciated.
Old 09-01-2013, 12:12 PM
Today I am going to change the crank sensor and take off the throttle body so I can get a good look at the three rear coil over packs--I was told to look for melting or some type of heat related issue on them. Then put everything back in and re-test. As a side note I read in the owners manual and confirmed on multiple websites that the pcm (or ecu) is covered under a federal emissions warranty for 8/80. I called dealer and they acted retarded about it so I guess if my efforts today fail to raise a spark I will print the pdf and stick it in their face on tues morning. I will continue to report here as time permits in hopes of helping some other person in the future.
Old 09-02-2013, 04:56 PM
Changed crank sensor with no change also did not see any problems with coil over packs and after a week of messin with it I am done--I suspect bad pcm according to my readings and inquiries. No spark and no codes. Will have it hauled to dealer and expect to have a tussle with them--we will see....
Old 09-04-2013, 01:32 PM
Dealer tested and it turned out to be PCM. They were great and told me all repairs are covered (someone please wake me up) under 8/80 fed emissions warranty. I will have one more followup post.
Old 09-04-2013, 05:32 PM
SleepyHead98's Avatar
SleepyHead98 SleepyHead98 is offline
What, I must be dreaming aswell!
"He who makes a beast out of himself gets rid of the pain of being a man."---Dr Samuel Johnson
