Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 08-27-2013, 08:56 AM
kool215 kool215 is offline
Cool 2000 oldsmobile bravada
2000 olds bravado, 110,000 miles, 4.3 liter engine. I had an accident and had to change the radiator and condenser, I drove the car for a few day with the radiator leaking into the engine before I replaced the radiator. Now the car starts ok, but has no power, when I press the gas pedal to the floor, the rpm would go up to 3000, then it would drop slow to below 1000 rpm and the car wants to stall, release the pedal it idle ok, press pedal and it wants to stall, no engine code, engine got wet from the leaking radiator before I changed it and all the problem started from that point.
Old 08-27-2013, 06:08 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2000 oldsmobile bravada
Check for a possible wet air filter or anything else restricting intake airflow.
Old 08-28-2013, 07:13 AM
I already removed the air intake to throttle body, and same problem. with throttle open engine loss power
Old 08-28-2013, 09:04 AM
When I press the gas peddle it goes to 1000 rpm from about 600 at idle, and it wants to stall. release the peddle and goes back to about 600 rpm. it would not go over 1000 rpm.
Old 08-28-2013, 09:25 PM
AF - Advisor
Check the fuel pressure.
Test kits are available at most chain type auto parts stores and Harbor Freight.
Here's where to connect,
Old 08-30-2013, 01:43 PM
Thanks all for your help it was the catalyst, replaced all is ok now.
The Following User Says Thank You to kool215 For This Useful Post:
Chris Stewart (09-02-2013)
Old 09-02-2013, 09:06 PM
AF - Advisor
Thank you for the update!
How was the bad catalyst determined?
TIA
Old 09-05-2013, 04:32 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Huh, too much back pressure. Was it at all related to the radiator leak?
Old 09-05-2013, 08:26 PM
Yes to much back pressure, due to the accident, with the radiator, and overheat, first the catalyst started to rattle and then no power.
Old 09-05-2013, 08:41 PM
AF - Advisor
I had an inner pipe close up on my 1968 Impala.
Power kept dropping so I drilled some holes at the junction of right/left pipes and power improved. Drilled a bunch of holes and power was restored....sounded good too.
