Old 08-22-2013, 06:24 PM
kenworth225 kenworth225 is offline
02 grand prix gt window problem
we had 3 windows stop working but the drivers window locks and mirror adj all work. the 3 passenger windows don't work on the doors or the master switch. just bought a new master switch thinking it was the lock out on the master switch, well no change!! windows still don't work any ideas???? thanks..
Old 08-22-2013, 07:57 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 02 grand prix gt window problem
Check for a broken wire(s) in the door wiring between the drivers door and the body ("A")pillar.
The Following User Says Thank You to gmtech1 For This Useful Post:
kenworth225 (08-28-2013)
Old 09-08-2013, 12:22 PM
well checked for broken wire and found nothing. now i can hear a slight clicking at the passenger doors. is it possible for all 3 doors to fail at the same time????
Old 09-08-2013, 04:06 PM
Tech II Tech II is offline
No, it's not possible for all three windows to fail at the same time...
The lockout feature on the master switch, only inhibits use of the windows at the other three switches, it does not affect the master switch...by that I mean, if you hit the lockout switch on the master, the RR window will not work at the RR switch....however, it will work at the master switch....
So, what I would do is start diagnosis, at one window, the RF...remove the switch from the door.....get a test light....ground it......
Five wires in the harness to the switch:
"A" Brown
"D" Lt Blue
"E" Dk Blue
"F" Dk Blue
"H" Tan
Tests are done with the key "on"...lockout "off"...
A. Backprobe terminal F of switch...test light should light...if it doesn't hit your lockout switch...if it still doesn't light, there is a problem with that circuit....if this fails, don't worry, it's not your main problem.....
B. With testlight still grounded, backprobe terminal D....on master switch, press RF UP...test light should light......if no, bad master or open wire....
C. backprobe terminal H...on master sw, press RF down, should light....if it doesn't, bad master or open wire...
D. Use your test light and back probe terminals H and D.....press mast RF down...should light....press master RF up, should light......
If test B and C are failures, since you replaced the master, the circuit that failed is open....
If B and C pass the test, but fail either the up or down test in D, it's a bad master switch(was this new or used?)....Power and ground to the master switch have to be ok, because the Driver's window works...
