Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 08-22-2013, 03:38 PM
bncase bncase is offline
00 air doesn't redirect
I have a 00 4cyl model that just blows air out the front vents and a little bit at feet and defrost. Can't change it, i couldn't find a person with the same problem anywhere on google or here. Should i get a air inlet door actuator or could i troubleshoot something else first, maybe the flap(s) are jammed, if so how can i unjamm, or is there a fuse?
Thanks
Old 08-22-2013, 08:17 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 00 air doesn't redirect
Thanks
The mode door actuator is vacuum operated. Check for vacuum leak at the vacuum tank under the hood, trace the hose from the hood to the a/c control head. If all the vacuum system is ok, pull the actuator off and try and manually move the mode door.
The Following User Says Thank You to gmtech1 For This Useful Post:
bncase (08-23-2013)
Old 08-23-2013, 05:40 PM
wow i fixed it for 1.50 all the vacuum hoses were bad, could i ask you another question? One of the hoses hooked into a fitting that came out of the driver side front fender, i couldn't tell if there was another hose that went somewhere else from the fender to maybe the interior of the car, so if it stops working again i probably need to replace that hose, or is it a metal tube?
Ben
