Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-21-2013, 09:37 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Transfer case fuse blows constantly
Hey guys,
My '99 Suburban 350 with the auto-trac 4wd is having electrical problems. The transfer case fuse always blows. I thought it may be the transfer case shift motor, so I took it out and tried and the fuse still blew. I tested the pins on the fuse, and sure enough they are shorted together, but only when the car turns on. This makes me think it's a relay issue. Anybody with a wiring diagram have any feedback?
Thanks,
Alex
Old 08-23-2013, 08:37 AM
j cAT j cAT is offline
Re: Transfer case fuse blows constantly
Originally Posted by ASJT3 View Post
Hey guys,
Thanks,
Alex
since you have a short circuit to ground you will have to look over the wires to around the transfer case. measure the fuse socket to ground with the battery negative removed. as you disturb these wires you should find the wire where it is damaged. could be the fuse box under the hood also . wires under it could be chewed up.
I doubt a relay would cause a short circuit. I would also give the name of this fuse and its amperage. this may get someone with a wiring diagram the ability to find what it feeds exactly.
Old 08-23-2013, 10:53 AM
thanks j_cat, it's the #2 fuse "Transfer Case," 20A. I unplugged the front diff actuator just in case that had anything to do with it but still blows the fuse. However, this time I noticed that after I put a new fuse in and turned the car on, the transfer case control module kept clicking, like there was a relay inside it opening and closing, before the fuse finally blew out after about ten seconds.
I hate being a newb but can you explain what I should be looking for by doing this/what it will tell me?
Thanks,
Alex
Old 08-23-2013, 04:07 PM
777stickman 777stickman is offline
Just to clarify somethings.
1. Is your Sub an Old Body Style or New Body Style?
2. You say it has "Auto-Trac". Is that what it really has or does it have a button that says "Auto 4WD"?
If it's OBS with "Auto 4WD" I may be able to help.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-23-2013, 04:15 PM
It's old body style (GMT400) with the "Auto 4WD" button. I thought this meant Auto-trac but I guess not...
Old 08-23-2013, 06:45 PM
OK. Let's see if I can help you.
1. The T-Case fuse #2 20a is "hot at all times". It supplies batt voltage all the time to the T-Case Control Module (TCCM) and to the T-case clutch control. This power wire is an orange one going to the TCCM & T-Case.
2. You said it "blows constantly" and then said it blows when the ign sw is turned on. So which is it?
3. If it blows when the ign sw is turned to "run" then I would suspect an internal short in the TCCM. You can try this by removing the C2 connector at the TCCM. It is a four wire connector with 2 blacks, a red & an orange.
57 Chevy 210
Old 08-26-2013, 01:54 PM
Thanks stickman, and I apologize for the confusion - it only blows when the ignition is turned to run. I'll remove the C2 connector and get back to you with an update!
Old 08-29-2013, 12:33 PM
So I unplugged the C2 connector from the TCCM and the fuse never blew.
I unplugged both connectors, removed the TCCM and took it apart, no obvious shorts, no debris behind the PCB, everything looked shiny new.
I plugged only the C2 connector back in, turned on ign a few times, no fuse blown.
With the #2 fuse out, I then plugged the other connector (the one w lots of wires) back in. When I plugged the fuse back in (both connectors in) and ign OFF, a relay inside the TCCM popped open/close a few times. Fuse still not blown.
I then turned ign ON, relay open/closed abt five times and did that each time I turned ign from OFF to ON. Service 4WD light would show. Still no fuse blown.
I tried turning ign on and off five times to clear/reset the TCCM, and after a few times doing that the fuse finally blew.
The Service 4WD light still showed after cycling ignition, so I'm guessing that it's actively throwing a code. I was going to try and pull the code by shorting ALDL connector #13 to GND and observing the 4WD switch light blink sequence.
Old 08-29-2013, 08:29 PM
since the fuse did not blow when the c2 connector was removed from the encoder motor large ga. wires I would say the encoder is in lock mode. unless the computer gets feed back to the encoder position or the control for the lock signal is broken this will occur. the other reason would be a damaged transfercase which means the encoder can not move because of damage. the encoder could be defective many have had the position sensors [small wires ] of the encoder get damaged then it will not move. the clicking could be the motor over current relay.
Old 08-30-2013, 12:28 PM
Thanks for the reply j_cat, I'm sorry I should have made it clear earlier that the encoder motor is unplugged. Actually, it's not even on the vehicle right now. I unbolted it to diagnose it and couldn't get the t-case selector shaft to fit back into the socket on the encoder motor - i'll cross that bridge again when i come to it.
So basically all the stuff above has been happening with the encoder motor physically off the vehicle. I'm going to go check again for frayed wires and try to trace some grounds.
When I was first trying to diagnose the problem, I unplugged the c2 connector from the encoder motor and blew on the contacts, plugged back in, and replaced the fuse. To my surprise, it seemed to work. The 4WD button lights came on, indicating the t-case was in 2WD mode. I couldn't resist tempting fate by pressing the 4WD-high button...I was afraid the fuse would blow leaving me locked in 4. The t-case successfully switched into 4, which I verified by driving for a bit, and then I tried switching to 2WD. The 2WD button light blinked for a bit then went off and the 4WD high light went solid again (as if it tried to switch to 2 and couldn't). At this point, the fuse blew, but luckily going into reverse somehow knocked the t-case back into 2WD.
So it appears the encoder motor/transfer case does work, but I've got this electrical demon which I need to chase down.
Old 08-30-2013, 02:12 PM
so from the connector you unplugged work back to the fuse box area. if those two wires short together the fuse will blow. many have had wire damage along the transfercase as the fasteners/loom fail. then the casting is abrasive.
Old 08-30-2013, 04:54 PM
After all you've done and posted (great job on that) I'm still leaning towards an issue with the TCCM. I would suggest a salvage yard try. There are 2 different TCCM's for '99. One for the older "selectable" 4WD with one connector. The one for yours has the 2 connectors. Give it a try and let us know.
57 Chevy 210
Old 09-15-2013, 09:39 PM
Thanks will do. Haven't had time to get to this, had to fix some things for MD inspection, including replacing input shaft seals on the steering box to fix a small leak. I'll re-check the wires by the t-case for fraying and also post back about the junkyard TCCM.
Old 08-10-2014, 09:27 PM
Well it's been a long time coming but I finally got around to fixing this today. After many hours of foolin around with this, I figured out that the transfer case wire loom was hanging on the driver side exhaust header; three of the wires were burnt/severed, including the ORN/TAN encoder motor wires. I spliced in new wire and voila, t-case/selector/encoder motor work! No Service 4WD light either!
However, the front axle actuator seems to be stuck in the engage position (maybe because the truck was in 4HI for a year?) The front tires still bind/chirp when turning. Will removing the actuator disengage the front axle? Can the actuator be tested plugged in but dismounted?
Thanks,
Alex
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 08-11-2014, 10:08 AM
so this is what I thought with some that had the loom damaged. only diff is the wires got into the exhaust. something was not put back correctly...
I would remove that front actuator and see if it is damaged or stuck.. clean it up if it looks good and see if it will work.
