Old 08-21-2013, 01:13 PM
avd's Avatar
avd avd is offline
Exclamation About Primer
So I was using Tamiya primer spray, but when I buy LHS, it cost over $10 and it's small and hate paying more. What happen if I just buy from home depot or lowes that is cheaper and bigger to save money. Will it be the same from Tamiya or different?
Old 08-21-2013, 01:20 PM
freakray freakray is offline
AF Modelrater
Re: About Primer
Completely different formulation, not that buying the right primer won't work, different brand and type of primers will be different.
I've successfully used Krylon primer before without issue, it just goes on heavier if you're not careful.
AF User Guidelines
The Following User Says Thank You to freakray For This Useful Post:
tonioseven (08-21-2013)
Old 08-21-2013, 01:23 PM
avd's Avatar
avd avd is offline
Re: About Primer
So Krylon primer is tougher than tamiya?
Old 08-21-2013, 01:31 PM
griffin-gt40 griffin-gt40 is offline
Re: About Primer
I get my primer from Walmart, labeled as Colour Place here in Canada cost about $3-$4 bucks a can and is about 3xs the size of Tamiya's large can. It's abit darker grey then Tamiya's light grey and abit heavy when applied but the cost differential is too good to pass up. I also buy my base colours from Walmart, I use the Krylon indoor/outdoor paint, costs about $4 a can and is often on sale for 2 for $5ish. I use black/flat white/flat flat aluminium and the clear and have had no issues as of yet with these paints reacting badly, even with Tamiya sprays. Only issue I had was two cans of glass black coming out like a mixture of flat/gloss. I contacted Krylon an they sent me 2 replacement cans as well as an extra can. Now I still use Tamiya paint for the specific colours that match particular race cars etc, but using the paint from Walmart saves a lot of money on the commonly used colours.
David
The Following User Says Thank You to griffin-gt40 For This Useful Post:
avd (08-21-2013)
Old 08-21-2013, 01:50 PM
stevenoble's Avatar
Re: About Primer
I only use the Tamiya primer as a final finish primer, applied before I paint. If I'm just checking my prep work, filling, sanding marks etc, I just use a cheap grey primer from Halfords (UK, auto store) A large can of that is really inexpensive and lasts ages. I wouldn't use it as my top coat primer as it's a bit grainy. But for 'roughing out' and checking my work it's great. Doing it this way keeps the costs down on the Tamiya primer as I use nowhere near as much..
Steve Noble
Old 08-21-2013, 02:11 PM
avd's Avatar
avd avd is offline
Re: About Primer
Hmm tough choice about primer. The colour place don't have here near my store. Only carry krylon paint.
Old 08-21-2013, 02:55 PM
Re: About Primer
Here it is from Walmart's website
Primer
http://www.walmart.com/ip/ColorPlace...White/17011150
Paint
http://www.walmart.ca/en/ip/krylon-i...black/10205794
David
Old 08-21-2013, 03:04 PM
avd's Avatar
avd avd is offline
Re: About Primer
Originally Posted by griffin-gt40 View Post
Oh I spell brand name wrong haha. ok cool I'll looking forward to try out. if it doesn't work well, i just go back to tamiya
Old 08-21-2013, 03:09 PM
Re: About Primer
Sorry, my fault, in Canada we use British English spelling for words like colour/flavour, etc. Its the same product just relabeled for sale north of the border.
Like Steve stated its, this is a heavier and thicker primer then Tamiya's fine, but a lot cheaper, especially if you are using it for checking work prior to final paint.
David
Old 08-21-2013, 03:12 PM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
Re: About Primer
If you are in the US you can use this. It's what I have used for years. spays on nicely. They even have a primer sealer which sands easily and thus helps in getting a nice glossy finish.
http://www.pepboys.com/car_care/paint/primers/00846/
On the other hand, if you use urathane paint, all you would wouldnt need primer. You would use adhesion promoter. Unless you used body filler of course.
Another day on the job!
The Following User Says Thank You to cjsbosox For This Useful Post:
avd (08-21-2013)
Old 08-21-2013, 03:31 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: About Primer
I've used duplicolor primer with good results in the past. But its laquer based so check scrap pieces first with paint. I love the tamiya primer i think its worth it lasts me for 2-4 bodies
In Progress
The Following User Says Thank You to MidMazar For This Useful Post:
avd (08-21-2013)
Old 08-21-2013, 03:50 PM
avd's Avatar
avd avd is offline
Re: About Primer
Awesome. Just trying out different primer which is good for me to used. Thanks guys
Old 08-21-2013, 06:01 PM
nascar49's Avatar
nascar49 nascar49 is offline
Send a message via AIM to nascar49 Send a message via Yahoo to nascar49
Re: About Primer
Avd, if you have a Hobby Lobby in your area, you might want to take a trip to one of the stores, they just started selling Tamiya Primer, and with the 40% off coupon, its a great deal, I just bought a can today from Hobby Lobby and after the coupon , I paid $7 and change
Pheedens Garage on Youtube
https://www.youtube.com/channel/UC4j...J8vUP1ZaHP32ig
Old 08-21-2013, 06:21 PM
avd's Avatar
avd avd is offline
Re: About Primer
Did that before, but can still small. I want something that is really big and stop going store everytime to buy
Old 08-21-2013, 09:41 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: About Primer
I use Duplicolor primer when I intend to use a hot paint, like another Duplicolor or touch up paint through an airbrush. I use Tamiya primer for just about everything. I use it on bodies if I am going to use TS for the body. I use it on pretty much all other parts, too, since I use TS on most of everything.
Remember, Tamiya primer is intended for plastic models. It won't react with the plastic, like can happen with Duplicolor and other hotter paints. It and TS sprays are docile, and easy to work with, too. I'm not saying Tamiya is always best for everything, I go through a LOT of cans of Duplicolor, too, but it is pretty good stuff, goes on super smooth, dries quickly, and work really well for hobbyists.
I had been building for years before I saw this page: http://www.tamiya.com/english/scale/beginner2/2.htm and it was an eye opener. Watch the video, it really changed my rattle can paint jobs for the better when I saw how close and fast they move the can. Made a world of difference.
The Following 2 Users Say Thank You to willimo For This Useful Post:
avd (08-21-2013), tonioseven (08-21-2013)
