Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 08-19-2013, 10:41 PM
Honda_Civic7 Honda_Civic7 is offline
Wheel bearings noisey after only a year
I just had my right front wheel bearings replaced about a little over a year ago. I'm starting to hear that same sound again when I get up around 45 MPH. I've only driven about maybe 8,000 miles since replacing them. It sounds like it's the right front again. Is this unusual for wheel bearings to fail this fast? Is it possible they did something wrong at the shop? Used cheap parts?
Old 08-20-2013, 11:46 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Wheel bearings noisey after only a year
No. this is not normal. If you did not "curb shot" the right front, then either cheap bearings were used, or the axle nut was over tightened, or both.
Old 08-20-2013, 01:14 PM
65comet's Avatar
65comet 65comet is offline
I've also seen them fail from under-tightening. A gap allows the inner and outer races to separate further. The bearings then start to ride on those edge points instead of the normal mating surface.
Old 08-20-2013, 04:45 PM
Right now it's not that loud and I have to get up to about 45 MPH before it becomes noticeable. Before it would be noticeable at about 35 and it was louder.
Do you think I will need to replace the whole thing again (obviously at a different shop)? Or is this something which can be "readjusted" in some way and cheaper?
Old 08-20-2013, 05:05 PM
gmtech1's Avatar
Nope, if the bearing is noisy, it's too late. Will need a new one.
Old 08-27-2014, 12:58 PM
Levithan9 Levithan9 is offline
Use TIMKIN BEARINGS. Kinda expensive, but will outlast your car.
