Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-17-2013, 08:54 PM
Marialyce Marialyce is offline
95' Dodge Neon problems
Hello, I have read through all of the older posts and still no luck. It wont start, We have replaced battery,wires, plugs, computer, cam sensor and crank sensor. the injectors and coil are not getting spark. we cant check for codes with the engine light because the gages wont work. We used a scanner and it showed no codes. ????? I would appreciate any ideas please. Thanks
Old 08-21-2013, 10:12 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 95' Dodge Neon problems
Have you checked the fuses and relays? ASD relay could be your problem.
2003 Dodge SRT-4
