Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-17-2013, 09:44 AM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Program 2012 Impala keys
I purchased 2 transponder keys from EBAY and will have them cut.
What is the CORRECT procedure for programming the keys to my 2012 Impala?
Thanks for your help!
John
Happiness is driving a Chevrolet!
Old 08-17-2013, 09:59 AM
Tech II Tech II is offline
Re: Program 2012 Impala keys
If you have a master key, it's simple.....GM has master and valet keys(usually a grey head)...you can't use this procedure with a valet key....
Insert master key into the ignition, turn to "on", wait two seconds, shut off and remove key.....then immediately insert new key and turn to on......should see SECURITY LIGHT in dash go out....turn to off, and then start car......same procedure for the other one.....
If master key is lost, it's a 30 minute procedure, where you insert new key, turn key to on, wait 10 minutes until the SECURITY LIGHT goes out, turn key to off, and then repeat 2 more times......(should have a battery jumper box on the vehicle for this procedure)...
The Following User Says Thank You to Tech II For This Useful Post:
SierraK1500 (08-17-2013)
Old 08-19-2013, 11:27 AM
Exclamation Re: Program 2012 Impala keys
Took both of my keys to the hardware store and had them cut. Fit the door which was a good sign. Programmed per your instructions. All keys start the car. Was the easiest program I have ever done. Just think the dealer wanted 47.00 each for a new key. I did it total 20.60. Thanks for your help.
John
