Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 08-15-2013, 06:50 PM
BrodysLSV8 BrodysLSV8 is offline
Lsv8 no reverse or drive
My 2002 lincoln ls v8 140k miles doesnt move when put into
reverse or drive5 or even d4,3,2,1 , it just starts to roll
back/forward when taken out of park. It has the gear selector
with d5,d4,3,2,1 not the select shift. I was told needs new
transmission, but before it stoped moving completely it was
still driveable second slipped at lower speeds(mostly when
looking for parking or in traffic). I had made an appiointment to
bring my car to the shop and the same day is when it stoped
moving. All this happen withn a week during the week i
constantly got an e where d5 was and on last day check engine
light came on. I just want a second opinion what someone might
think it can be. Any help/advice is/would be highly appreciated.
Thank you for reading
brody
Old 08-15-2013, 09:56 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Lsv8 no reverse or drive
It's probably not in need of a completely new/different transmission, but rather an issue with the fluid (condition or level), the pump, or valve body.
And I'd like you to confirm that the car does not roll when in park. If the will roll in park, then the issue may be as simple as a broken u-joint or driveshaft issue.
-Rod
Old 08-15-2013, 11:11 PM
No roll in park. But I have replaces both u joint and drive shaft
Old 08-16-2013, 10:38 AM
joegr joegr is offline
I would agree that it is probably something as simple as being low on fluid or having a bad solenoid assembly, if you hadn't been driving it while it was slipping. I do suspect that you have destroyed your transmission.
Old 09-05-2013, 02:16 PM
danielsatur danielsatur is offline
Also see http://www.automotiveforums.com/vbul....php?t=1065882 ,it could be a bad plastic shifting block, or a loose shifting cable.
