Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-15-2013, 06:33 PM
Moneer81 Moneer81 is offline
How to Understand an Estimate Regarding Ball Joint Replacement
Hello,
During an oil change, the shop suggested this:
"Ball joint - Remove and Replace - LS,In-Line4 Control Arm, Lower,One Side"
Does this mean it is the front left ball joint?
Do I need to replace the whole control arm and ball joint assembly?
Also, I am getting new tires and an alignment. Does anyone know if it is okay to get the tires and alignment first and then replace the ball joint?
Thanks!
Old 08-15-2013, 07:17 PM
maxwedge maxwedge is offline
A990 racer
Re: How to Understand an Estimate Regarding Ball Joint Replacement
That vehicle may have the ball joint as part of the lower arm, did you ask the shop? I would do the joint first then the tires and alignment.
Old 08-15-2013, 08:40 PM
Thanks!
So do you happen to know what side they're referring to in that estimate statement? What does "LS,in-line4" mean?
Old 08-15-2013, 08:46 PM
kevinande's Avatar
kevinande kevinande is offline
LS means left side. I am not sure about that in line4 business.
1998 Escort ZX2
2004 Mazda RX8
2007 Honda Accord
2011 Ford F150
Old 08-16-2013, 03:55 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
As Max stated, the ball joint is service with the control arm. Get the parts replaced before the tires and alignment. "line 4" may refer to the 4th line on the repair order?
