Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-14-2013, 11:31 PM
DonSor DonSor is offline
Cooling Problem
This not really a cooling problem as my P/U truck ('99 Ranger 4.0L) is not overheating. My P/U however seem to take a much longer time to warm up based on checking how long it will take for the upper radiator hose to go from a cold start to a point where the hose will be too hot to touch (indicating the stat opening up). Could it be the stat or maybe the fan clutch?
Old 08-14-2013, 11:38 PM
kevinande's Avatar
kevinande kevinande is offline
Re: Cooling Problem
Sounds like the thermostat may be stuck open. It's a good place to start your troubleshooting. If a stat is going to fail, better it fail open rather than closed.
1998 Escort ZX2
2004 Mazda RX8
2007 Honda Accord
2011 Ford F150
Old 08-17-2013, 11:29 AM
ASE AMD ASE AMD is offline
Re: Cooling Problem
Water exits the engine on upper hose. It won't get hot until the motor is hot and thermostat opens. Running the heater will cool the engine.
Old 01-30-2014, 08:21 PM
lectraplayer lectraplayer is offline
Re: Cooling Problem
Also check your water if you have not done so.
Old 01-30-2014, 11:02 PM
Re: Cooling Problem
The stat was OK but the fan clutch was malfunctioning in that it was not responding to the temperature change. It was not the spring but rather it was the viscuous fluid. Nonetheless I replaced the fan clutch and the temperature control seemed to be OK now.
