Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-12-2013, 10:32 PM
brocsbar brocsbar is offline
Question Blinkers Alternate w/lights on
I got a 2007 GMC Sierra 5.3 Vin Z with a electrical blinker/light problem. Works fine in the rear but in the front have the problem. With no headlights on the front, the front blinkers work normal but when the lights are on and the left blinker is on the 2 left blinkers in the front alternate and the same when the right blinkers are on with the lights ---they alternate between themselves. By alternate i mean the two bulbs on the SAME side (in the front) flash at different times. But Don't when the headlights are off, then they both blink together as they should. The rear lights on the truck aren't affected but the MAIN problem is that I pull a trailer and when it is hooked up to the trailer and I have on EITHER blinker they both alternately blink in the rear (but not on the truck)
Old 08-13-2013, 01:42 PM
Re: Blinkers Alternate w/lights on
Nobody? I've tried to look at the DRL's but they aren't a factor. (they don't work on their own but when I supply ground to the relay under the hood they work) but it doesn't change the way the blinkers react. Light Switch?? Any and all insight is very appreciated.
Old 08-13-2013, 02:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Does this have a factory trailer harness/trailer brake set up?
Old 08-14-2013, 02:12 PM
Yes it does. I've checked out that both his trailers are wired right
Old 08-14-2013, 04:43 PM
gmtech1's Avatar
Checked the bulbs? They can do funny things when they have problems.
Old 08-18-2013, 09:30 AM
Yup checked all bulbs and sockets
Old 08-19-2013, 05:42 PM
I'm changing the headlight switch tonight and will let you know
