Old 08-12-2013, 05:24 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
'99 Vortec 350, Code P1509 (High Idle)
Hey Guys,
Got my first truck with a 350 Vortec engine, 244K miles. I've got a SES light with code P1509,
"DTC P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding"
That's the only code that's thrown. The engine idles around 1000 RPM and will sometimes surge while driving between 1200-2000 RPM. I googled this code but not much came up. I've seen that a multitude of things can cause high idle, but since I'm getting a code with the symptoms, is this a pretty clear cut case of needing to replace the IAC valve?
Thanks,
Alex
Old 03-14-2014, 02:48 PM
Re: '99 Vortec 350, Code P1509 (High Idle)
So I've been dealing with this issue for about 7 months now, thought it was most likely the intake manifold gaskets. Well...this morning I replace the lower intake manifold, intake plenum, and throttle body gaskets, and not a dang thing changed. Still have the high idle.
I've replaced the distributor cap/rotor, IAC valve, IAT sensor, ECT sensor, and PCV valve. I've sprayed down the top side of the engine with carb cleaner looking for vacuum leaks, haven't found any.
I no longer get 1509 since I replaced the IAC, but now the only code I get is 0507 (Idle higher than expected).
Any ideas? This is driving me crazy and can't get the car emissions inspected til I fix it.
[EDIT] I should add, the problem gets much worse as the car warms up. Makes me think it's not getting ECT (even though i changed the sensor). Truck gets lousy gas mileage.
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 03-15-2014, 10:25 PM
777stickman 777stickman is offline
So many things to consider. New IAC not adjusted properly prior to install, IAC relearn not performed, EGR bad, PCV bad, Spider assy bad, pressure regulator bad, map bad, TPS bad, someone prior to you messed with the idle stop screw, etc,etc.
You might consider an Alldata subscription for this issue.
http://alldatadiy.com/
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-24-2014, 06:37 PM
OK, I hooked up an ELM 327 obdii to usb scanner, using free scanTool.net.
Here are my specs at IDLE:
RPM: ~1300 (damn!)
Calculated load: 5.1%
Timing advance (Cyl 1): ~17.0 deg
Intake Manifold Pressure: 8.6 inHg
MAF flow rate: 1.6 lb/min
Engine coolant and air temp readings seem to be normal (192 deg, 50 deg).
Anything jump out at anybody?
Thanks,
Alex
Old 03-24-2014, 06:47 PM
Should be around 15-20"!!
57 Chevy 210
Old 03-25-2014, 08:04 AM
Hmm.. Now this is the absolute manifold pressure correct? I measured ~20 inches vacuum using a gauge, so 29in atm minus 20 inches vacuum ~8.6. Seems right?
Now, i forgot to say something else, the truck came with a K&N filter. I checked and cleaned the MAF sensor, looked fine. Not possible that the filter is too high flow is it? When I tried to drive with the filter (accidentally) knocked off the intake tube, truck would sputter when I gave it gas. When I "choked" the flow with my hand, idle lowered considerably, to a reasonable level.
Old 03-25-2014, 08:31 AM
maxwedge maxwedge is offline
A990 racer
Right about the vacuum readings that is how the pcm calculates it. Possible the iac itself is bad or carboned up.
Old 03-25-2014, 08:36 AM
As i said initially, I replaced the IAC to try and fix this problem, no change.
Old 03-25-2014, 11:43 AM
A990 racer
Should have seen that, anyway a highline bi-directional scanner can command the pcm to change idle speeds by taking over the iac, then you can see what may be happening, remember a dirty throttle plate can cause this also.
Old 03-25-2014, 12:50 PM
Interesting, I would like to be able to do that, I'll look into it.
When I changed the intake manifold/plenum gaskets last week I cleaned the throttle plate pretty well, doesn't seem to be letting any air bypass it. This evening I might take off the throttle body, remove the IAC and TPS and clean their bores out really well.
Old 03-26-2014, 05:22 PM
Wow. Problem solved.
I took off the throttle body for cleaning and noticed that the throttle plate didn't close all the way. Looks like the previous owner had adjusted the throttle plate stop screw to leave it open somewhat. Loosened it up until the throttle plate closed all the way, now idles like a charm!
However, this makes me curious...why would anyone do such a thing?
Old 03-26-2014, 06:25 PM
A990 racer
Because they didn't know what they were doing this also skews the tps setting.
Old 03-26-2014, 08:48 PM
Strange. Anyways, thank you and everyone else for help in solving this issue!
