Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-10-2013, 06:39 PM
x24 x24 is offline
truck wont start
I have a 95 ram that won't start. When i turn the key over to start it, there is a spark at the positive terminal on the battery and i lose power (dome lights, ignition etc.). If i move the positive cable at the battery, i regain power again. Any suggestions on what the problem could be would be appreciated.
Old 08-10-2013, 10:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: truck wont start
You have a bad battery connection that can destroy the sensitive electronics of your truck $$$$$.
Remove the battery cables, clean them and the battery terminals with a steel or brass brush until they're shiny clean then reinstall them.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
The Following User Says Thank You to Chris Stewart For This Useful Post:
x24 (08-25-2013)
Old 08-11-2013, 06:42 AM
x24 x24 is offline
I've cleaned the posts on the battery and it's made no difference.
Old 08-11-2013, 12:17 PM
AF - Advisor
What about the cable end?
If the cable itself is loose at the cable end, a replacement end will need to be acquired.
The cable will need to be cut from the old end, cable insulation trimmed and installed at the new end.
If the spark is at or sort of under the battery post, the post itself may be broken.
The battery will likely need to be replaced.
Most chain type auto parts stores do free battery checks in hope of earning your patronage. I'd give them that chance.
x24 (08-25-2013)
Old 08-11-2013, 03:29 PM
aleekat aleekat is offline
Sounds like your cable is bad or your battery has an internal short.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
x24 (08-25-2013)
Old 08-25-2013, 09:44 AM
x24 x24 is offline
thanks for the help
Old 08-25-2013, 09:52 AM
x24 x24 is offline
I put a new battery in and that seems to have cured the problem. However, I have developed a new problem that i need help with. The truck is refusing to start again. It isn't getting any fuel or spark. When I turn the key over, the ignition coil and injectors only get power for about 3 seconds and that's it. when I try to start the engine, there's no power to the coil or injectors. I have a code that comes up; 12 problem with battery connection. direct battery input to pcm disconnected within the last 50 ignition key-on cycles. any advice would be greatly appreciated.
Old 08-25-2013, 07:52 PM
AF - Advisor
Check the fuel pump & ignition breakers in the power panel under the hood.
See if they're getting hot.
Old 08-31-2013, 08:45 AM
x24 x24 is offline
I checked them and they're not getting hot.
Old 09-02-2013, 09:09 PM
AF - Advisor
Do other electrical devices work, like the headlamps & horn?
Old 09-04-2013, 04:21 PM
x24 x24 is offline
yes everything else works (lights horn radio). It seems to be only ignition and fuel that are affected.
Old 09-08-2013, 08:04 PM
AF - Advisor
I'm starting to suspect the crankshaft position sensor...it tells the computer the engine is running, it won't provide spark or fuel to an engine that is turned off.
Is the Check Engine light on?
You may need to borrow a scan tool to see what the computer thinks.
Old 09-12-2013, 03:39 PM
jrsick jrsick is offline
Yep, CPS is probably the problem.
