Old 08-10-2013, 02:04 PM
NHTrooper NHTrooper is offline
Smile Silverado instrument cluster problem
I have a 2003 Silverado 6.6 liter diesel with 190,000 on it and have been having problems with the gauges. On occasion the gauges that have an arm (mph, tach, battery, water temp, oil pressure,etc) would stay pinned at their starting point. The digital stuff (mileage, low fuel light, etc) would be fine. If I shut the truck off and re-started it all would be well. Yesterday I had the same problem and despite several re-starts the gauges remain pinned. Any thoughts out there? BTW, I'm a novice type who can change tires and oil but everything else is new to me. Thanks in advance.
Old 08-11-2013, 01:25 PM
j cAT j cAT is offline
Re: Silverado instrument cluster problem
this model year time period GM used defective , what they call stepper motor devices. this was an extended warranty coverage. look this up on the internet and also call dealership about this failure. if they refuse to fix this can be sent out [dash panel] for new dash motors to be installed . you can drive the vehicle with it removed .
since your not all that auto tech type find a auto electrical repair shop with experience with this.
dealership does not repair these dash indicators. they only change parts. so what can happen is they may install someones dash panel not yours now you got a mileage issue and then that causes problems with the vehicle/registry . more B/S paper work. that is why it is best if you send out your dash to be repaired and then it is the same.
The Following User Says Thank You to j cAT For This Useful Post:
NHTrooper (08-11-2013)
