Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-08-2013, 03:54 PM
VinceH VinceH is offline
2000 Rodeo running rough
So I just had both cats replaced and now the car is running very rough and trowing out mis-fire codes. What could cause this? Going to disconnect the battery to reset the computer to see if that might help.
Any thoughts welcome
Thanks
Old 08-12-2013, 08:42 PM
Re: 2000 Rodeo running rough
So the system has been reset and the cars does run better however a new problem has come up. When idling in traffic or at a stop light, the CE light comes on. Had the code red and come up with the random misfire. The cars feels to run well..
Could this be that the car has 195k mile on the ignition coils or could this be a result of a low current and the battery needing to be changed.
What is the best way to diagnose which could could be failing?
Thanks
Old 08-12-2013, 08:43 PM
Thanks
Old 08-12-2013, 10:50 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I would start with changing the plugs ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-13-2013, 12:24 PM
the plugs were just changed within the last 15k miles. I will pull them and check their condition.
Old 08-13-2013, 06:19 PM
Isuzu Guy
what brand of plugs?
-Ryan
Isuzu Moderator
Car Show Tips
Old 08-16-2013, 07:43 AM
Denso and they look great
Old 08-17-2013, 02:48 PM
jamesslcx jamesslcx is offline
Have you checked fuel pressure? Checked for vacuum leaks? Cleaned your throttle body? Ran fuel system cleaner in the tank? Many things can cause those misfire codes.
Old 10-14-2013, 02:37 PM
Does anybody know what the fuel pressure ( high and low)
Should be at the fuel rail? 2000 rodeo 3.2l v6
Thanks
