Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-08-2013, 02:14 PM
comet240 comet240 is offline
00 1500 what color is Reverse Wire under dash
hi I like to wire up another set of lights for reverse but don't wanna tap into the ones at the end but run a new wire and use a relay under the dash
but the Haynes book doesn't tell me the color 18br/lg
I figured maybe brown light green strip and a 18 gauge wire but didn't see it under tthere
so any help be great thanks
Old 08-08-2013, 02:37 PM
aleekat aleekat is offline
Re: 00 1500 what color is Reverse Wire under dash
Not sure about the color coding. But here is a link for a 2001 Factory Service manual download. Section 8W has rear lighting diagram. http://dodgeforum.com/forum/2nd-gen-...tmas-guys.html
Old 08-08-2013, 03:31 PM
same as hayes book doesn't say really the color except L10 18 BR/LG by the switch but even hoping that the wiring was under the hood easier to access
as by the tail lights its LT 18 VT/Bk
guess I gotta take console out to find the wiring lol
Old 08-08-2013, 07:07 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
That's circuit L1, 18 gauge wire and it's violet and black.
Don't unplug the #1 Joint Connector in the Power Distribution Center (underhood fuse box) and turn the keyswitch on...it'll set off a bunch of codes.
Mine set off P0122. p0230, P1492, P1693 and the death code to a diesel...P1689.
I reset them all with my scan tool.
It's all ok now.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 08-08-2013, 07:32 PM
ok what does the L1 mean? and I cant find the violet black wire just found the pinkish and purple wire haven't unplugged any cables yet
you don't have a pic of the wiring under ur dash? or is there a good spot to tap into under the hood
I spent a long time trying to find this crap
the diagrams I don't really understand as they not your typical wiring diagrams that are straight through like GM books
but where abouts is the violet black wire be great as I having hard time finding it
Old 08-09-2013, 06:40 PM
AF - Advisor
Which transmission?
Old 08-09-2013, 07:57 PM
AF - Advisor
For an auto trans, check page 2390 of the service manual for the switch location then trace back to the violet/black wire.
Old 08-09-2013, 08:04 PM
k thanks that wasn't in the section I was looking couldn't even see that page too late now
I thought the switch was in the shifter in the steering column and I coulnt find the wire in the mesh of wires with the 1 bolt that holds the harness on
so what I did which was easier I just ran 2 wires to the rear tail light and tapped into the purple black wire and it went to the relay under the hood an the 2nd wire powers the 2 55w flood lights but like something brighter or more lights lol
but ill have to remember that the park neutral switch is also the neutral switch
